Post by wangwang on Jun 23, 2018 12:19:19 GMT 1
Am I correct in assuming that the brown wires in an LC loom are +ve , but are only 'live' when the ignition is turned on?
I'm wiring in a digital thermometer and just need to be sure before I splice it in.
Cheers wang
Post by Tobyjugs on Jun 23, 2018 15:05:34 GMT 1
Yes
Post by earthman on Jun 23, 2018 16:24:14 GMT 1
Am I correct in assuming that the brown wires in an LC loom are +ve , but are only 'live' when the ignition is turned on? I'm wiring in a digital thermometer and just need to be sure before I splice it in. Cheers wang Why not check with a multi meter or probe before you fully cut into or splice the particular wire that you are looking at?
Post by wangwang on Jun 23, 2018 22:08:03 GMT 1
Am I correct in assuming that the brown wires in an LC loom are +ve , but are only 'live' when the ignition is turned on? I'm wiring in a digital thermometer and just need to be sure before I splice it in. Cheers wang Why not check with a multi meter or probe before you fully cut into or splice the particular wire that you are looking at? Think I'll have to check a few wires, no neutral light, horn or brake light, ffs!
Post by 4l04ever on Jun 23, 2018 23:51:45 GMT 1
If you drop me a PM with your email address, I can email you a colour wiring diagram for an LC. :-)
Post by wangwang on Jun 24, 2018 10:13:20 GMT 1
If you drop me a PM with your email address, I can email you a colour wiring diagram for an LC. :-) Cheers 👍
Post by dllc on Jun 24, 2018 10:42:01 GMT 1
i had this issue. fault was where all the black wires join in the loom. peel back around 6" from top and you will find them.
