Post by graham198 on Jun 17, 2018 13:36:31 GMT 1
Hi how much should I be looking at for a micron fork brace for a 350lc thanks
Post by russpuss on Jun 17, 2018 15:27:45 GMT 1
As cheap as possible as a buyer or as much as possible as a seller!
Post by jackjabba on Jun 17, 2018 15:46:00 GMT 1
Does it have to be Micron? Check Norbo's parts he sells fork braces.
Post by veg on Jun 17, 2018 16:11:31 GMT 1
I paid £100 for a used one for which I could of nearly bought a brand new one from norbo. But because of my build it had to say micron on it.
Post by graham198 on Jun 17, 2018 18:10:56 GMT 1
Been offered one £160 posted is this too much
Post by russpuss on Jun 17, 2018 18:12:45 GMT 1
Been offered one £160 posted is this too much Sounds about right to me, I got mine a bit cheaper a few years ago but would have paid £150 plus post.
Post by graham198 on Jun 17, 2018 18:58:49 GMT 1
Ok thanks so £160 is ok just I don’t want to be ripped off lol
Post by russpuss on Jun 17, 2018 19:02:30 GMT 1
Ok thanks so £160 is ok just I don’t want to be ripped off lol The decision is yours! You can get Fastec 1’s for £112 off eBay, but it don’t say micron like Veg says.
Post by paulincayman on Jun 17, 2018 19:06:02 GMT 1
A genuine item seems to be considered a collectors item at this stage. I hope it has the ding in the top from the brake line banjo. A nice period correct addition to your project.
Post by jackjabba on Jun 17, 2018 19:21:07 GMT 1
£160 of just bling, its your money. I would put the money towards a new shock or something worth having.
Post by veg on Jun 17, 2018 19:35:32 GMT 1
It is always dependent on what you want I want one to go with the period look of my build, do they do anything worthwhile probably highly debatable. And as jackjabba says there are better ways to spend the cash, but if you want period then thats cool. If it doesn't need to say micron on it then as other have said you can get them new from norbo or fast etc for £110 ish
Post by graham198 on Jun 17, 2018 19:50:39 GMT 1
A genuine item seems to be considered a collectors item at this stage. I hope it has the ding in the top from the brake line banjo. A nice period correct addition to your project. Yep it has the mark in the top from the brake is it worth £160 then
Post by russpuss on Jun 17, 2018 19:52:51 GMT 1
A genuine item seems to be considered a collectors item at this stage. I hope it has the ding in the top from the brake line banjo. A nice period correct addition to your project. Yep it has the mark in the top from the brake is it worth £160 then Get it bought
Post by panzermatt on Jun 17, 2018 20:23:05 GMT 1
i have one.....i wasn't going to put it back on.
Post by panzermatt on Jun 17, 2018 20:26:19 GMT 1
Post by panzermatt on Jun 17, 2018 20:27:34 GMT 1
having said that it's for a 31k. just spotted you want one for an lc.
Post by graham198 on Jun 17, 2018 21:03:50 GMT 1
having said that it's for a 31k. just spotted you want one for an lc. Ya I need one for a lc thanks anyway
Post by paulincayman on Jun 17, 2018 21:18:47 GMT 1
i have one.....i wasn't going to put it back on. Let me know if you are selling it..would appreciate first dibs on it if it can work on F2 forks . Both 35mm but not sure on muddy mounts.. Paul
jarvy
Post by jarvy on Jun 18, 2018 5:54:24 GMT 1
I paid 75 swiss francs for mine, NOS still in original box including p&p.
Post by jackjabba on Jun 18, 2018 7:57:11 GMT 1
Look on ebay completed listings to see what they have been selling for. Only you can decide if its worth £160 to you. I understand Veg's point about a period look and sometimes when You want it You have to have it.
Post by 4l04ever on Jun 19, 2018 16:39:31 GMT 1
i have one.....i wasn't going to put it back on. Let me know if you are selling it..would appreciate first dibs on it if it can work on F2 forks . Both 35mm but not sure on muddy mounts.. Paul Does not fit on F2 forks. They are designed for 31K which are different.
Post by paulincayman on Jun 19, 2018 17:15:46 GMT 1
Let me know if you are selling it..would appreciate first dibs on it if it can work on F2 forks . Both 35mm but not sure on muddy mounts.. Paul Does not fit on F2 forks. They are designed for 31K which are different. Ok, thanks for the advice.
Post by vic6169 on Jun 21, 2018 12:14:18 GMT 1
I have a Micron one for an LC I won't be using if anyone is interested.....
Post by greeny on Jun 21, 2018 12:27:46 GMT 1
Pm'd you.
Post by graham198 on Jun 23, 2018 21:51:15 GMT 1
I have a Micron one for an LC I won't be using if anyone is interested..... Hi I’m interested in the brace is it for a lo if so how much
Post by beardy on Jun 27, 2018 7:45:56 GMT 1
i was looking at the above pics by panzermatt. so had a look at my brace as i did`nt recall seeing any graphics on mine as above. what i have on mine is a 54 mark on each clamp half. does anyone know what this means? genuine or copy? thanks
Post by 4l04ever on Jun 27, 2018 11:19:05 GMT 1
54 is the Outside Diameter of the top of the lower fork leg where the Micron brace clamps on to. 4L0/4L1 size. 58 or 58G is for a 31K with 58mm OD on top of fork leg lowers.
