SVA
Jun 16, 2018 19:23:27 GMT 1
Post by ypvs400 on Jun 16, 2018 19:23:27 GMT 1
My Tigcraft framed YPVS is coming together nicely and I plan to road register the bike and fit it will full electrics including lights etc so it will be practical ish to use on the road, my question is has anyone gone down the SVA route ? as the bike has a one off frame and many one off parts made and fitted I was wondering is there anything I need to take into consideration beyond the obvious that would cause problems come SVA time.
SVA
Jun 16, 2018 19:28:43 GMT 1
via mobile
ypvs400 likes this
Post by midlifecrisisrd on Jun 16, 2018 19:28:43 GMT 1
Nah
Get a scrap ypvs frame with a v5, stamp the number on the headstock then cut up the ypvs frame😁
Amazing what you could do in the 80's
I have a mate with a Harris magnum and it is simply registered as a z1
SVA
Jun 16, 2018 19:29:53 GMT 1
Post by ypvs400 on Jun 16, 2018 19:29:53 GMT 1
Nah Get a scrap ypvs frame with a v5, stamp the number on the headstock then cut up the ypvs frame😁 Amazing what you could do in the 80's I have a mate with a Harris magnum and it is simply registered as a z1 Steve It did pass my mind
SVA
Jun 16, 2018 19:48:29 GMT 1
via mobile
ypvs400 likes this
Post by midlifecrisisrd on Jun 16, 2018 19:48:29 GMT 1
Is anybody seriously going to query it?
Not as if it is being passed off as an original ypvs
Do you think plod will say "that's not the correct font"
I do have a v5 from a chopped frame 😉
SVA
Jun 16, 2018 22:43:36 GMT 1
via mobile
ypvs400 likes this
Post by lrcarl on Jun 16, 2018 22:43:36 GMT 1
Nah Get a scrap ypvs frame with a v5, stamp the number on the headstock then cut up the ypvs frame😁 Amazing what you could do in the 80's I have a mate with a Harris magnum and it is simply registered as a z1 Steve It did pass my mind [br Go for it,happens all the time in the custom world Carl
SVA
Jun 16, 2018 23:58:53 GMT 1
via mobile
ypvs400 likes this
Post by bryan on Jun 16, 2018 23:58:53 GMT 1
Try and avoid SVA as you need to comply with current rules, massive pain in the arse. Get a set of letter and number punches!
Any frame number and V5 will do, don't need to be from a 2 stroke bike does it.
SVA
Jun 17, 2018 8:08:16 GMT 1
via mobile
Post by ypvs400 on Jun 17, 2018 8:08:16 GMT 1
Try and avoid SVA as you need to comply with current rules, massive pain in the arse. Get a set of letter and number punches! That was my concern, emissions and noise level may be the bikes downfall.
Post by fozzy17 on Jun 17, 2018 8:13:05 GMT 1
as above buy a ypvs frame use the numbers on the custom frame, not legit but your not a criminal just making life easy, a friend of my has a tz race bike road legal, it uses 3xv frame numbers
SVA
Jun 17, 2018 11:29:51 GMT 1
ypvs400 likes this
Post by bryan on Jun 17, 2018 11:29:51 GMT 1
Tony at Gibson was sorting an Marborough RD500 with a MiCo frame from Oz and had to hand stamp the black frame with alocated frame number, plus loads of other stuff required to meet SVArequirements, was a right pain. Loads os silly little thimgs, it's doable but can be a lot of work.
SVA
Jun 17, 2018 11:33:41 GMT 1
via mobile
Post by midlifecrisisrd on Jun 17, 2018 11:33:41 GMT 1
Don't you need ABS for a 2018 registered bike
Q plate otherwise
Also needs to be something like 95% new
SVA
Jun 17, 2018 13:39:17 GMT 1
ypvs400 likes this
Post by bryan on Jun 17, 2018 13:39:17 GMT 1
forgot, it will be on a Q plate too, any Yamaha frame number and V5 will do the job.
SVA
Jun 17, 2018 16:25:05 GMT 1
via mobile
ypvs400 likes this
Post by midlifecrisisrd on Jun 17, 2018 16:25:05 GMT 1
Pm me if you want my v5, sure I still have it
Obviously free
UK 31k lc2 A???ERA
I personally cut up the frame and destroyed the headstock
Post by bryan on Jun 17, 2018 18:06:59 GMT 1
My advice it take the V5
SVA
Jun 19, 2018 16:54:18 GMT 1
ypvs400 likes this
Post by 4l04ever on Jun 19, 2018 16:54:18 GMT 1
FZR400 frames are also cheap to come by....
SVA
Jun 19, 2018 18:17:20 GMT 1
via mobile
ypvs400 likes this
Post by midlifecrisisrd on Jun 19, 2018 18:17:20 GMT 1
The bonus of using a ypvs frame number opposed to an fzr is that as it's a steel frame technically you could have used a ypvs headstock and built the frame around it 😉
