Post by Tobyjugs on Jul 1, 2018 17:23:02 GMT 1
Have you now got the 21cc domes fitted?
Post by stusco on Jul 2, 2018 7:09:26 GMT 1
Yes 21cc domes
Post by 4l04ever on Jul 2, 2018 8:48:48 GMT 1
I have just rebuilt my 4L0 top end and got my squish very close to 1mm now. It is close to optimum for LC engines if you want to keep a little safety margin :-)
Post by stusco on Jul 2, 2018 17:15:53 GMT 1
Just checked the compression 122 psi left pot 121psi right pot exhausts fitted carbs,pv,oil pump all adjusted ,gear box filled with oil , ill leave it until tomorrow to fire it up,to give the rtv silicone on the exhausts a chance to set
Post by stusco on Jul 3, 2018 17:34:24 GMT 1
Fired up first kick on remote tank ,bled the oil pump ,filled with coolant,ran it round the block still feels poky ,I will give it a run tonight, How many miles would you run in a new piston and rings no rebore?
Post by midlifecrisisrd on Jul 3, 2018 17:54:02 GMT 1
50 to 100 miles just to bed it in 😁
Good luck
Post by stusco on Jul 3, 2018 17:57:11 GMT 1
Cheers Steve
Post by Tobyjugs on Jul 3, 2018 18:02:45 GMT 1
let it warm up and cool down a couple of times. Keep an eye on the plugs. I mark the throttle and check a1/4, 1/2, 3/4 and full thottle to see what is happening.
Post by Tobyjugs on Jul 3, 2018 18:13:44 GMT 1
Post by stusco on Jul 4, 2018 17:32:01 GMT 1
let it warm up and cool down a couple of times. Keep an eye on the plugs. I mark the throttle and check a1/4, 1/2, 3/4 and full thottle to see what is happening. “I mark the throttle and check a1/4, 1/2, 3/4 and full thottle to see what is happening” What are you looking for,I don’t what another disaster? i did five miles at no higher than 4000rpm last night there’s no colour on the plugs
Post by jessy03 on Jul 4, 2018 18:25:10 GMT 1
What jets are you on, I have the same set up,I’m on 27.5/300 Jess
Post by stusco on Jul 4, 2018 19:01:53 GMT 1
What jets are you on, I have the same set up,I’m on 27.5/300 Jess pwk28 158 main 42 pilot jjh needles middle position 3.5 slide pod filter tsa pipes mick abbey fast road
Post by Tobyjugs on Jul 4, 2018 20:18:57 GMT 1
Hi Stusco i always use old plugs as they seem to react quicker to the carb settings i just monitor the colour of the plug at the different markings. If it is light at any given mark than i know i have to be carefull in that area until I've adjusted the jetting.
Post by Tobyjugs on Jul 4, 2018 20:20:24 GMT 1
I forgot to say good luck and to do it properly get it set up on a dyno.
Post by stusco on Jul 4, 2018 22:23:03 GMT 1
I’ll be making an appointment with mutts sometime soon cheers for the advice
Post by headcoats on Jul 5, 2018 8:24:04 GMT 1
Was the 158 main in the bike when it seized or have you gone up while setting it back up again ?
I know all bikes are different but I have run 152 mains for years with Ramairs,VForce, TSA pipes and Mick Abbey tune and pre mix
It was probably on the needle when seized , was it on middle clip when it happened or have you richened it up since ?
Post by tsa on Jul 5, 2018 9:25:19 GMT 1
From the O-ring it looked like a sudden ingress of water that caused the issue.
Post by stusco on Jul 6, 2018 16:35:57 GMT 1
I haven’t changed any settings since the rebuild Just done 70 mile at around 5-6 grand here are the plugs r
Post by Tobyjugs on Jul 6, 2018 17:49:57 GMT 1
The right one looks leaner than the left. Try swapping the plugs over left to right to check if it is the carburation or the plugs
Is this a plug chop or just taken out after you got home for a ride?
Post by stusco on Jul 6, 2018 18:00:40 GMT 1
Just took the out after a ride I’ll try swapping them Cheers
Post by mattybeckett on Jul 6, 2018 18:20:07 GMT 1
Right hand one deffo looks lean, did it come out of the cylinder that had the problem last time as it could be a clue. Are they 8s or 9s?
Post by stusco on Jul 6, 2018 19:14:34 GMT 1
They are 9’s I’m 90% sure they are the right way round so no
Post by stusco on Jul 7, 2018 15:32:35 GMT 1
Fitted a couple of old plugs that were a bit rich looking did ten miles
Post by stusco on Jul 7, 2018 15:34:06 GMT 1
Photos are deceiving they are both the same,I will give it the berries and do a chop
Post by Tobyjugs on Jul 7, 2018 15:42:36 GMT 1
Do a couple of chops at different throttle positions and build up to WOT
Post by bare on Jul 7, 2018 16:17:15 GMT 1
Mere curiosity: in very First photo.. the Mounting flange of the right Cyl is notably thinner than that of the Left one. Seems as a curious thing
Post by bare on Jul 7, 2018 16:18:32 GMT 1
double post sorry.
Post by mattybeckett on Jul 7, 2018 18:12:42 GMT 1
They both look ok to me. Worth getting a borescope as great for looking at top of pistons to see the colour. Also handy for other jobs.
Post by stusco on Jul 7, 2018 19:18:48 GMT 1
They both look ok to me. Worth getting a borescope as great for looking at top of pistons to see the colour. Also handy for other jobs. Got one I’ll have a look
Post by stusco on Jul 7, 2018 19:20:26 GMT 1
Mere curiosity: in very First photo.. the Mounting flange of the right Cyl is notably thinner than that of the Left one. Seems as a curious thing Do you mean the exhaust flange as one has had a repair
