Post by bid on Jun 1, 2018 19:18:38 GMT 1
hi all, ive just finnished the clutch cover mod, ive used 6mm lexen glass but it has a bit of warpage as i tightend it down, for anyone in the know, will it be ok, cheers folks
Post by Yogi on Jun 1, 2018 19:37:24 GMT 1
Hi mate I've had them warp,probably from over-tightening and heat from riding Anyway it did leak I ended up using silicone but left it loose overnight,then nipped it up It's still ok now Matt
Post by Yogi on Jun 1, 2018 19:38:51 GMT 1
Also Norbo does a stainless ring that helps in his shop for £10 I think
Post by bid on Jun 1, 2018 19:47:00 GMT 1
cheers Matt thats good to know, i,ll do the silicone trick then, best regards, dave🙂
Post by ukcalling on Jun 1, 2018 19:48:49 GMT 1
Any chance you could post the O ring sizes you used?
Cheers Nick
Post by bid on Jun 1, 2018 20:04:44 GMT 1
hi Nick, i used 3mm viton rubber o ring cord, get it by the meter of ebay, then i fitted it to the outside indent cut it to size then super glued it to make a 118mm ring and then did it again inside of that o ring, so its got 2 o rings one slightly bigger than the other, then for the scews halfords box of assorted rubber o rings and then fibre washers on the outside, hope that helps, thanks all best regards, dave😉
Post by mattybeckett on Jun 1, 2018 20:51:16 GMT 1
I can't see the point in doing this TBH?? unless there is some sort of fancy clutch inside the casing to put on show with loads of other mods to go with the bike. Oh well every one to there own
Post by markhoopy on Jun 1, 2018 21:05:13 GMT 1
I can't see the point in doing this TBH?? unless there is some sort of fancy clutch inside the casing to put on show with loads of other mods to go with the bike. Oh well every one to there own They are purely for entertainment value in biker cafe meets etc .. sit with the engine ticking over and count how many passers-by stop and watch the clutch spinning round, either transfixed by the beauty of it all or trying to figure out why the engine is running backwards ..
Post by bid on Jun 1, 2018 21:08:12 GMT 1
to see any probs eg, water or 2t oil ingress like ive had in the past, shame they didnt put a sight glass in as standard, save all the hard work, and it looks nice, kind regards, dave
Post by lrcarl on Jun 1, 2018 21:27:07 GMT 1
I can't see the point in doing this TBH?? unless there is some sort of fancy clutch inside the casing to put on show with loads of other mods to go with the bike. Oh well every one to there own Clutch adjustment,spring swop.using solid cover in stead of window on mine Carl
Post by rigga on Jun 1, 2018 21:42:12 GMT 1
Quick oil level check before starting the bike. It is just a gimmick tho.
Post by loudpipes on Jun 1, 2018 22:05:11 GMT 1
Works fine for me easy to adjust clutch and add weights.
Post by loudpipes on Jun 1, 2018 22:06:20 GMT 1
Post by bid on Jun 1, 2018 22:27:50 GMT 1
ohh lovely,👍👍👍😉
Post by donkeychomp on Jun 1, 2018 22:38:20 GMT 1
I think it's very trick. Is there a company that does the conversion or is it easy enough to do myself?
Post by bid on Jun 1, 2018 23:03:23 GMT 1
hi Alex, ive just done it myself, but nk racing does it £55, cost me about £15 all in, and not hard at all, a drill and a good curved file, oh and a jig saw and a steady hand for the clear lexen sheet, but norbos just started to do em on his lovely online shop, regards, dave😉
Post by donkeychomp on Jun 1, 2018 23:24:25 GMT 1
Cheers Dave. Might leave this job to the pros lol. £55 sounds fair enough as it looks kinda tricky!
Post by bid on Jun 1, 2018 23:29:55 GMT 1
yeah i dont blame you, you get a nice cnc'd o-ring groove too, i dont have that on mine sadly, just hope it doesnt leak, seals look good though, 🤞
Post by bid on Jun 2, 2018 21:26:18 GMT 1
all good so far after adding a little silicon too, marvelous, no leaks, i like it, jolly good show chaps😅
Post by donkeychomp on Jun 2, 2018 21:59:52 GMT 1
Brilliant!
Post by bare on Jun 3, 2018 3:05:16 GMT 1
Just like having your Very Own Laundromat on your bike.
Post by robin on Jun 3, 2018 9:44:22 GMT 1
I really like the look of this mod and have done for sometime, being able to actually see and hear where all the clutch rattles are coming from! - Hmm not for me yet, will need to cure all the clutch rattles first.
