Post by bezzer on May 27, 2018 11:02:07 GMT 1
Post by jackjabba on May 27, 2018 11:38:24 GMT 1
Hi Bezzer, I haven't used the Yambits one, but have the one Norbo sells. There doesn't seem to be a lot of difference and its a fair bit cheaper.
Post by bezzer on May 27, 2018 12:27:18 GMT 1
Hi Bezzer, I haven't used the Yambits one, but have the one Norbo sells. There doesn't seem to be a lot of difference and its a fair bit cheaper. Cheers Jack, I had a look on Norbo’s page but didn’t see one?, his link wasn’t working for me yesterday either??.
Post by jackjabba on May 27, 2018 12:44:22 GMT 1
Hi Bezzer, I haven't used the Yambits one, but have the one Norbo sells. There doesn't seem to be a lot of difference and its a fair bit cheaper. Cheers Jack, I had a look on Norbo’s page but didn’t see one?, his link wasn’t working for me yesterday either??. Norbo's is £85 and out of stock.
Post by midlifecrisisrd on May 27, 2018 13:00:35 GMT 1
Cheers Jack, I had a look on Norbo’s page but didn’t see one?, his link wasn’t working for me yesterday either??. Norbo's is £85 and out of stock. He needs to order more from Yambits 🤣🤣🤣 Steve
Post by stusco on May 27, 2018 15:40:11 GMT 1
Hi Bezzer, I haven't used the Yambits one, but have the one Norbo sells. There doesn't seem to be a lot of difference and its a fair bit cheaper. Cheers Jack, I had a look on Norbo’s page but didn’t see one?, his link wasn’t working for me yesterday either??. The link in the for sale section doesn’t work anymore I have to go in through www.rdlccrazy.co.uk/
Post by bezzer on May 27, 2018 15:46:18 GMT 1
Cheers Jack, I had a look on Norbo’s page but didn’t see one?, his link wasn’t working for me yesterday either??. The link in the for sale section doesn’t work anymore I have to go in through www.rdlccrazy.co.uk/Ah, Cheers Stusco, it was the link that I tried to access mate, will use the website in future 👍🏻.
Post by spookoverload on May 28, 2018 10:44:39 GMT 1
I'm searching for this answer too lol. Have a few mm play in mine so need to sort it, saw this kit, about to order but then saw your "marmite reputation" quote & thought I'd best see if anyone posts lol
Looked a good idea but if it's naff quality?? Still for the few hundred miles it will do every year, can it be any worse than what I have now
Post by bezzer on May 28, 2018 19:08:26 GMT 1
I'm searching for this answer too lol. Have a few mm play in mine so need to sort it, saw this kit, about to order but then saw your "marmite reputation" quote & thought I'd best see if anyone posts lol Looked a good idea but if it's naff quality?? Still for the few hundred miles it will do every year, can it be any worse than what I have now Hi Mate, I only say ‘marmite reputation’, as if you look back at threads on this forum, some members say avoid them like the plague, others say they’ve used their parts without issue. I do agree with your view though, how much worse can it be than a near 40 year old part with commensurate wear?.
Post by jackjabba on May 28, 2018 19:47:52 GMT 1
Honestly Yambits stuff is usually fine. The oil pump cable on the their throttle cables was never the correct size and others have reported problems with crank shaft oil seals. To be fair I used their crankshaft oil seals with no issues and they were still good after 8 years. I only replaced them with originals when I recently did a full engine rebuild.
Try the swinging arm repair kit, if its no good let them know and ask for your money back, or just wait for Norbo to get more stock.
Post by bezzer on May 28, 2018 20:17:49 GMT 1
Sage advice Jack, cables and crank seals - you’re better using original parts, as they’re still available.
The swing arm kit has to be better than using the stock nylon bushes etc, I’ll give it a go.
Post by simon998 on May 28, 2018 20:53:02 GMT 1
Where are you getting the new cables Bezzer? Need a throttle cable and clutch cable and oem would be great. Or what are the best cables these days?
Post by spookoverload on May 28, 2018 22:38:32 GMT 1
I've ordered a kit, will let you know how it works :-) Not fun wibbling & wobbling out of fast corners
Post by donkeychomp on May 28, 2018 22:50:31 GMT 1
Every Yambit part I have bought has been perfect. But I'd avoid any cable and am amazed the oil seals lasted 8 years, use gen Yam ones.
Post by bezzer on May 29, 2018 0:01:00 GMT 1
Where are you getting the new cables Bezzer? Need a throttle cable and clutch cable and oem would be great. Or what are the best cables these days? Hi Simon, Got OEM throttle, clutch and speedo cables for my 250 from Fowler’s. Not cheap, but great service, they acknowledge your order and keep you informed of delivery etc.
Post by donkeychomp on May 29, 2018 0:03:31 GMT 1
+1 for Fowlers
Post by 0h5h1t on May 29, 2018 7:00:13 GMT 1
+1 for fowlers. Excellent service and always quick delivery.
Post by simon998 on May 29, 2018 9:34:09 GMT 1
Where are you getting the new cables Bezzer? Need a throttle cable and clutch cable and oem would be great. Or what are the best cables these days? Hi Simon, Got OEM throttle, clutch and speedo cables for my 250 from Fowler’s. Not cheap, but great service, they acknowledge your order and keep you informed of delivery etc. Excellent, cheers. I always get a lump in my throat after I add a few items from fowlers into my basket and notice the price lol.
Post by JonW on May 31, 2018 22:54:34 GMT 1
Nk also makes a good kit. Cheap too.
Post by 4l04ever on Jun 1, 2018 7:36:29 GMT 1
You can get phosphor bronze swing arm bushes off Norbo instead of the plastic ones. There is also a later "white metal" type bush available from Yamaha.
Post by KevtheRev on Jun 7, 2018 8:05:59 GMT 1
I fitted the Yambits swingarm kit . Looked good quality and went in fine . Time will tell , lol .
Post by bezzer on Jun 7, 2018 8:24:30 GMT 1
I fitted the Yambits swingarm kit . Looked good quality and went in fine . Time will tell , lol . Thanks for the update Kev. My kit has arrived, but not had chance to fit it yet, as I’m away with work. As you say, the quality looks fine though.
Post by copper99 on Jun 7, 2018 15:28:42 GMT 1
Every Yambit part I have bought has been perfect. But I'd avoid any cable and am amazed the oil seals lasted 8 years, use gen Yam ones. Alex ...Throttle cable for my 500 fitted fine, when items are NLA the choice sometimes only comes down to a ropey 30+ year old one off eBay or Yambits. Id rather buy new from Yambits if that is the option.
