Post by philmill on May 11, 2018 18:09:03 GMT 1
So i've been thinking about using a YZF125 dash on my Hybrid, one of the good things is it an electronic speedo with a drive on the front wheel. The problem is the spindles smaller, so I wondered if anybody had tried to increase the size of a drive? Its got a fairly chucky metal centre but holding it to machine may be a problem. I just wondered.
Phil
Post by midlifecrisisrd on May 11, 2018 19:01:04 GMT 1
Not done it but imagine it's difficult and may destroy it
Would also be concerned about the strength left in it
I'd get a meter on it and check if it is just a pulse sender like a magnet ant reed switch which I'd guess it is.
If one pulse per revolution just get a koso sensor and a magnetic disc bolt
Post by philmill on May 11, 2018 19:33:19 GMT 1
Cunning Steve, hadnt though about the disc bolt idea.
Post by earthman on May 11, 2018 20:53:11 GMT 1
If you went down the machining route, how about making an 'adapter' that would fit into the drive instead? Assuming that you have enough space to fit such a converter piece in??
Post by philmill on May 12, 2018 7:24:37 GMT 1
I'm still looking at options here, the 125 unit is worth a try ad the bits are so cheap, I like the idea of a "Yamaha" unit but still may go down Koso or R1 units yet.
Phil
Post by lrcarl on May 12, 2018 9:26:49 GMT 1
I'm still looking at options here, the 125 unit is worth a try ad the bits are so cheap, I like the idea of a "Yamaha" unit but still may go down Koso or R1 units yet. Phil If you go with the koso idea send me a pm I got the bits you need(Foc) Carl
Post by jon on May 12, 2018 9:31:59 GMT 1
Yep, I’ve done it to a Yamaha drive.
It looks to me that are all the same blank, and then drilled to size. I can’t comment on your model though.
I couldn’t find my FZR one, so drilled our a YPVS one to put a rolling chassis together.
Typically I’ve now found the FZR one, Doh.
Post by philmill on May 12, 2018 9:41:31 GMT 1
The issue will still be mating the drive to the RGV wheel, not sure it will be possible as RGV uses the 4 pieces to locate and drive it.
Phil
Post by jon on May 12, 2018 11:09:34 GMT 1
The issue will still be mating the drive to the RGV wheel, not sure it will be possible as RGV uses the 4 pieces to locate and drive it. Phil I’ve never worked with RGV stuff, so I’m no expert. However do I remember correctly from threads on here that RGV drives have 2 prongs and GSXR have 4? Maybe I’ve got it the wrong way round? Jon
