Post by philmill on May 10, 2018 14:05:38 GMT 1
So I sent the crank away to PJME for strip and check and they have come back and said it needs rods etc, so going to cost £310 quid. Is there any other way or any cheaper options? I think I've seen somebody selling cranks at sensible money but are they any good? At least I know if PJ do it it will be right and done correctly, but a big chunk of change I hadnt budgeted for, It ran sweet as so foolishly thought just mains and away i go Crank rebuild, rebore and a mild tune equals big bucks Phil
Post by rd350rob on May 10, 2018 14:16:16 GMT 1
Norbo does all new Japanese ones for £345.......
Post by midlifecrisisrd on May 10, 2018 15:14:08 GMT 1
Unless it needs webs Grampians are about £240
Post by philmill on May 10, 2018 15:29:22 GMT 1
Thats interesting Steve, the quote is for rods and bearings, centre shaft and seals, and mains. So maybe Grampians are cheaper, would be a bit cheeky to get it back and send it to Grampians!
Phil
Post by 4l04ever on May 10, 2018 15:33:02 GMT 1
Thats interesting Steve, the quote is for rods and bearings, centre shaft and seals, and mains. So maybe Grampians are cheaper, would be a bit cheeky to get it back and send it to Grampians! Phil but considerably cheaper.....
Post by paulsx on May 10, 2018 16:01:26 GMT 1
I always used PJME but they quoted me £95 to overhaul a fs1e crank a few months back. Grampian did it for £65 including return postage
Post by Norbo on May 10, 2018 16:04:02 GMT 1
£220 exchange is what i charge for an all new recon crank with everything replaced
Post by philmill on May 10, 2018 17:15:40 GMT 1
Hi Norbo, so if I get it back from Pjme will you take it in exchange even is it’s stripped?
Post by midlifecrisisrd on May 10, 2018 17:38:00 GMT 1
The centre shaft may be pushing the price up
I posted one to Grampians this morning, they should have it Monday so I'll expect it rebuilt Tuesday and have it back in my hands Wednesday
I'll get back with the quote
Can't believe I was selling cranks still in spec for £50 last year and now I need another to rebuild for my next motor.
Post by Deleted on May 11, 2018 4:42:46 GMT 1
The centre shaft may be pushing the price up I posted one to Grampians this morning, they should have it Monday so I'll expect it rebuilt Tuesday and have it back in my hands Wednesday I'll get back with the quote Can't believe I was selling cranks still in spec for £50 last year and now I need another to rebuild for my next motor. Steve That stuff happens to me. Sold a lot of spares for my LC thinking I would never get another one. Then presto, another LC.
Post by JonW on May 11, 2018 5:02:25 GMT 1
and me... even gave away a bunch of bits to a local lad and then had to buy more of the same from ebay... sigh
Post by jackjabba on May 11, 2018 9:00:04 GMT 1
I got a used one from Mark last year for £100 and its still in in the box it arrived in. I keep buying stuff and then changing my mind. Need a 4mm stroker crank now.
Post by budgie on May 11, 2018 20:11:43 GMT 1
+1 for Grampians.... very fast ,efficient and honest service...They have done a few for me , always a no fuss service...Although Paul at PJME has done cranks and bores for me in the past..with no problems...only started using Grampians as they had a remarkably fast turnaround when I needed a race crank doing..! And kind of stuck with them...!
Post by andy71330 on May 11, 2018 21:50:26 GMT 1
whats the general opinion for a crank going with the 391 bore kit
Post by muttsnuts on May 16, 2018 9:32:32 GMT 1
whats the general opinion for a crank going with the 391 bore kit works perfectly fine
Post by Deleted on May 16, 2018 10:14:37 GMT 1
I think you are all very cheeky talking about crank reconditioning on Norbos forum when he offers a new and an exchange service at very competitive prices
Post by philmill on May 16, 2018 10:56:20 GMT 1
I didnt realise he did them, and he is now supplying my new one
Post by midlifecrisisrd on May 16, 2018 16:27:43 GMT 1
Don't think we are being cheeky, he asked for options which we gave
As it turns out mine is fecked
Inner webs knackered so ended up at £315 posted
I've spoke to norbs about cranks before and he says this is the problem, he exchanges at 220 then gets robbed on the next one
Wouldn't send one unless I knew I'd was good for straight rebuild
Surprised the pins and outer webs were all ok as it was as sloppy as an old tart.
