Post by jon on May 5, 2018 13:45:46 GMT 1
Hi all,
I’ve just stripped my YPVS forks down after fully rebuilding them with genuine seals and bushes etc.
I wasn’t 100% happy with the chrome on the stations. They looked OK when I built them, but after leaving the rolling chassis in the rain a few times (to make space in the garage to work) I noticed a few tiny pin pricks of rust just starting.
I stripped them back today and what a hassle.
The screw holding the damper rod in just spins the damper rod when you try to undo it.
I know some FZR’s have a hex socket in the damper rod, but the YPVS doesn’t.
Had to drill the screws out in the end. There must be a better way?
Maybe machine the damper rods to accept a hex or similar?
Post by midlifecrisisrd on May 5, 2018 14:01:00 GMT 1
Yes a pain in the ads when the rod spins
I usually get an allen socket and a few 3/8 extension bars down on-site to get some pressure on the rod, doesn't take much
The correct tool is like a tapered barb
Post by philmill on May 5, 2018 14:13:57 GMT 1
I usually find an impact gun will shift them, I've had a few stubborn ones over the years, a real pain in the bum.
Post by jon on May 5, 2018 14:19:20 GMT 1
Yes a pain in the ads when the rod spins I usually get an allen socket and a few 3/8 extension bars down on-site to get some pressure on the rod, doesn't take much The correct tool is like a tapered barb Steve That’s a good idea Steve. I could make such a tool for next time. A morse taper holds things in my lathe tighter than expected. A rod of the right taper, held in a vice and tap the forks onto it to bind the damper rod would be a good idea. Thanks. Jon
Post by rich on May 5, 2018 15:33:10 GMT 1
Impact wrench plus loosen them first of all while the fork is complete. This way the spring is pressing on the damper rod helping prevent it from rotating.
Post by jon on May 5, 2018 16:52:53 GMT 1
Impact wrench plus loosen them first of all while the fork is complete. This way the spring is pressing on the damper rod helping prevent it from rotating. Another, top tip to try next time. Jon
Post by 0h5h1t on May 5, 2018 22:11:17 GMT 1
Impact wrench plus loosen them first of all while the fork is complete. This way the spring is pressing on the damper rod helping prevent it from rotating. +1 never failed yet. do this on all the right way up forks I strip
Post by urbantangleweed on May 5, 2018 23:54:52 GMT 1
Had the same thing last week, tried everything and still the damper rod turned, broke out the impact gun and it span 'em straight out.
Post by cbm on May 6, 2018 4:37:51 GMT 1
The investment of around a tenner does away with all that pain, just ignore the offensive language at the top of the link - Thingy
Link to shop
Post by jon on May 6, 2018 7:18:58 GMT 1
Link to shopI can see the proper tool, but can’t work out how to hold it still. Clamped in a vice maybe? Jon
Post by midlifecrisisrd on May 6, 2018 9:59:16 GMT 1
Usually a t bar on the top of it
Post by steeley on May 6, 2018 13:53:38 GMT 1
In the past I have used a piece of broom handle with a point on it .
Post by bare on May 6, 2018 17:45:42 GMT 1
As above :-) Impact gun on the bolt end... Pointed wood implement on the other Instant off... and on.
Post by cbm on May 7, 2018 5:15:50 GMT 1
Usually a t bar on the top of it Steve Yep, extension with T bar, a light tap on the end of the extn then lay the fork flat the T bar holds it's self. You can also but a one piece tool for about £15 with an L handle on top, basically it's just a length of 1/2" bar machined down to a taper at one end and bent to 90 degrees at the other.
Post by dusty350 on May 7, 2018 7:28:02 GMT 1
I had this problem in the past with Gsxr forks. A Gixxer forum member at the time recommended shamferring down the end of a wooden broom handle and jamming it into the top of the damper rod. Worked a treat !! Once apart I made a special tool that was basically a T bar with an upside down bolt on the bottom end. The bolt head fitted the hex on the top of the damper rod so it could be held securely. Gotta say the broom handle was just as good though Dusty
Post by huggy76 on May 7, 2018 21:22:46 GMT 1
I did the seals on my YPVS forks the other week and used some wooden dowel that i think was once a curtain rail, worked just fine for me.
Post by reggieperrin on May 8, 2018 17:08:47 GMT 1
Crack the bolts with an impact wrench whilst still assembled or even on the bike.. (using a front stand of course) Never had some needed drilling out.
Post by bertiemollie on May 9, 2018 22:23:30 GMT 1
Impact gun always worked for me when they spin. I don't have a gun but my local friendly dike shop undoes them for me when I'm struggling.
