Post by Tobyjugs on May 4, 2018 9:28:39 GMT 1
I'm working away at the moment, so i can't check my bike. The bike is fully built up with pod filters. I have been thinking about putting the original air box back. is this an engine out job?
Post by Deleted on May 4, 2018 10:21:20 GMT 1
I wouldn’t have thought so
A bit of airbox yoga may be in order though
Post by stusco on May 4, 2018 10:40:52 GMT 1
Engine out
Post by Deleted on May 4, 2018 10:41:47 GMT 1
Wow, how weird is that
I stand corrected
Post by wallcraft on May 4, 2018 10:52:08 GMT 1
Done it many times, in/out. Install through the oil tank side with it hanging out.
Post by wallcraft on May 4, 2018 10:57:25 GMT 1
Just to comfirm after reading what I wrote, English was never my strongest at school! Definitely can be installed with the engine in.
Post by stusco on May 4, 2018 11:02:42 GMT 1
No I stand Corrected
Post by 4l04ever on May 4, 2018 11:05:36 GMT 1
Engine in. Can make more room with inlet rubbers off if required.
Post by markhoopy on May 4, 2018 11:23:10 GMT 1
Done it many times, in/out. Install through the oil tank side with it hanging out. +1 easier than removing the engine too
Post by arrow on May 4, 2018 11:51:26 GMT 1
I've done it with the engine in. It was a while ago, but I vaguely remember you have to manoeuvre the two large bits in and then join them together while roughly in place. Yes, it's possible. Good luck.
Post by abar121 on May 4, 2018 11:51:42 GMT 1
Yeah, remove inlet rubbers. It can be easier to unbolt the rear shock too.
Post by Tobyjugs on May 4, 2018 12:36:37 GMT 1
Cheers for the advice chaps
Post by rich on May 4, 2018 20:22:56 GMT 1
Did mine but think I had to take just the right side inlet rubber off
