Post by russpuss on May 3, 2018 21:46:14 GMT 1
Builders out there, do you install the tie bars still?
Post by jessy03 on May 3, 2018 21:52:18 GMT 1
Yes you can Russ Jess
Post by russpuss on May 3, 2018 21:53:44 GMT 1
I’ve the tie bar frame and 31k engine, just not sure if people fitted them or not as I’ve not got any? I can buy some I suppose as I’m only collecting at the minute.
Post by stusco on May 3, 2018 22:02:43 GMT 1
I think everyone fits them if they can
Post by markhoopy on May 3, 2018 22:09:47 GMT 1
They are there for a reason - your engine will move about in the frame if you don't fit them and eventually something will break. Exhausts first I would think ..
Post by russpuss on May 3, 2018 22:11:34 GMT 1
Fair play guys, looks like I’ll be needing a pair then, cheers.
Post by foxyjohn on May 4, 2018 15:39:20 GMT 1
I have run my Hybrid for 28 years without Tie Bars and not had a problem
Post by rigga on May 4, 2018 16:59:07 GMT 1
Most replacement pipes have slip joints and spring retention at the head, that would resist breaking unlike the standard pipes.
Post by russpuss on May 4, 2018 17:00:57 GMT 1
Most replacement pipes have slip joints and spring retention at the head, that would resist breaking unlike the standard pipes. I’ll be having 2t cats make some for me as going on the Shocker, just wondered if needed the bars or not
