Post by dusty350 on May 2, 2018 19:44:02 GMT 1
Hi I may need to do a stem swap on the Rg125 yokes I have. The stem is shorter than on a 250 Rgv, meaning the stem nut might not have enough threads to act upon. Are stems basically pressed out, and then back in ? There is no evidence of welds anywhere so I imagine they are an interference fit ? Dusty
Stem swap
May 2, 2018 20:17:36 GMT 1
via mobile
Post by lrcarl on May 2, 2018 20:17:36 GMT 1
Some stems welded if not should just press out Carl
Post by headcoats on May 2, 2018 20:46:34 GMT 1
My RGV one is welded but when NK did my KR1S bottom yoke , he shortened it then pressed it in but also drilled and tapped for a grub screw to add strength
Post by Mr Kipling on May 2, 2018 20:59:14 GMT 1
Yep without the weld simply press out , the NK grub screw is a worthy thing for peace of mind on reassembly...
Post by gammaguy21 on May 7, 2018 14:32:59 GMT 1
Headcoats, do you know if NK pushed the stem from top to bottom t get out or from the bottom out? What exactly do you mean by NK shorted it?
I can't get the rgv stem to move... but I'm only using a 12 ton press.
Post by steeley on May 7, 2018 16:51:44 GMT 1
Hi Rgv you say . steel lower yolk . If so there will be a weld round the stem .
Post by headcoats on May 7, 2018 17:21:00 GMT 1
Headcoats, do you know if NK pushed the stem from top to bottom t get out or from the bottom out? What exactly do you mean by NK shorted it? I can't get the rgv stem to move... but I'm only using a 12 ton press.
Sorry I don't know and it was 10 years a go too
Remember mine was a KR1S stem too but the RGV one I do have is welded on
Post by gammaguy21 on May 9, 2018 19:57:14 GMT 1
Thanks headcoats.
