Post by doohanno1 on Apr 29, 2018 22:14:42 GMT 1
Anybody ever made a " bolt on " side stand spacer to stop the stand retracting to much and hitting the exhaust pipe.? Tks
Post by rigga on Apr 29, 2018 22:27:38 GMT 1
Mine has a drilling taped to accept a small Allen bolt, stops the sidestand hitting the exhaust (BMW stand) can just see it in the pic below, possible to do the same to the original stand?
Post by doohanno1 on Apr 30, 2018 16:38:34 GMT 1
Thanks for that.. I had an over complicated idea in my head that i couldn't make anyway.
Post by markhoopy on Apr 30, 2018 17:02:51 GMT 1
I had an over complicated idea in my head that i couldn't make anyway. Same as the rest of us then
Post by veg on Apr 30, 2018 18:29:53 GMT 1
Having a side stand made by Nk because when you fit his rear sets you can’t fit the standard one. Inspired bit of marketing 😀
Post by jon on Apr 30, 2018 18:33:10 GMT 1
Anybody ever made a " bolt on " side stand spacer to stop the stand retracting to much and hitting the exhaust pipe.? Tks I don’t know exactly what you mean, but understand the stand hitting the exhaust. In a lot of cases this is wear in the pivot area. The spring then pulls the stand towards the exhaust. I mount my springs on the outside so any wear will pull it further from the exhaust.
Post by oldelsieboy on Apr 30, 2018 18:50:46 GMT 1
Anybody ever made a " bolt on " side stand spacer to stop the stand retracting to much and hitting the exhaust pipe.? Tks I don’t know exactly what you mean, but understand the stand hitting the exhaust. In a lot of cases this is wear in the pivot area. The spring then pulls the stand towards the exhaust. I mount my springs on the outside so any wear will pull it further from the exhaust. The wear to the hole in the frame mounting bracket & the sidestand is easily rectified by fitting some appropriately sized bushes. OEB
Post by jon on Apr 30, 2018 19:01:35 GMT 1
I don’t know exactly what you mean, but understand the stand hitting the exhaust. In a lot of cases this is wear in the pivot area. The spring then pulls the stand towards the exhaust. I mount my springs on the outside so any wear will pull it further from the exhaust. The wear to the hole in the frame mounting bracket & the sidestand is easily rectified by fitting some appropriately sized bushes. OEB This may be a quick fix for a worn hole, but it something I check on all projects before powder coating the frame. Beat way is weld up and re-drill proper size. Jon
Post by doohanno1 on Apr 30, 2018 21:05:16 GMT 1
Yes,some great idea's there.. It's like as if the powder coat had taken up the slack and has now worn.. P.S. i should of put a bush on the gear shaft aswell..doh.!!
doggs
Post by doggs on May 1, 2018 0:05:58 GMT 1
had same problem - all i did was use a very thin washer/shim like you find on gearbox output shafts to reduce back lash etc and fitted that between the side stand and the frame mount - this took up the free play and now the stand does not hit the exhaust - its a bit of a tight fit mind and the side stand takes a good tug - come on keep it clean - to put down but i would rather have the stand a bit stiff than flapping about on a worn pivot
