Post by 3tj6 on Apr 28, 2018 20:33:42 GMT 1
As title , going to have a look at a jmc swingarm for a lc tomorrow, it has extended wheel adjusters not eccentric ones? Is that right? Anybody got any info or pics ?tia jon
Post by howard on Apr 28, 2018 21:41:39 GMT 1
Got one in my bike .
Post by 3tj6 on Apr 28, 2018 22:06:22 GMT 1
Thanks howard for the pics, the one im looking at has2 down tubes from the upper brace to the lower arm? Are all jmc the same?
Post by donkeychomp on Apr 29, 2018 1:06:00 GMT 1
Some have eccentric ones and I'd avoid them. Had one on a Z650 and it was a bugger to set the chain properly. Maybe it's just me... Alex
Post by dusty350 on Apr 29, 2018 9:59:01 GMT 1
No, not just you Alex - my Metmachex that was bought brand new has those adjusters that aren't nearly as accurate as they claim to be Wished I had opted for the extended "normal" type of adjusters but that was a £60 option top of all the other options they charge you for at Metmachex, but I couldn't justify nearly £900 on a swingarm !!! Dusty
Post by dusty350 on Apr 29, 2018 9:59:47 GMT 1
Plus when you adjust your chain tension it alters the ride height !!
Post by donkeychomp on Apr 29, 2018 11:36:32 GMT 1
It did too!
Post by 3tj6 on Apr 29, 2018 19:18:47 GMT 1
Well i had a look , metmachex with normal extended chain adjusters, £150 , so i bought it 👍 just got to get fzr 3tj wheel to fit in it 🙏
Post by dusty350 on Apr 29, 2018 19:33:50 GMT 1
Sounds a bargain A 2ma wheel would probably fit ok too Dusty
Post by oldelsieboy on Apr 29, 2018 19:49:00 GMT 1
Well i had a look , metmachex with normal extended chain adjusters, £150 , so i bought it 👍 just got to get fzr 3tj wheel to fit in it 🙏 Isnt a 3tj rear wheel rim 4.5" wide, very doubtful that will fit a standard width LC arm of any make. OEB
Post by 3tj6 on Apr 29, 2018 20:21:20 GMT 1
Anybody know the length of a standard lc swingarm from middle of rear spindle to middle of swingarm spindle? From small to long on chain marks on swingarm? Tia Jon
Post by 3tj6 on Apr 29, 2018 20:27:26 GMT 1
Oeb , the extended chain adjusters are very wide, and I know i have to get the sprocket carrier and caliper carrier milled down to fit, if it carnt be done then i will use the dt lc arm I already have, anybody know of someone with a milling machine near Sheffield?😉
Post by oldelsieboy on Apr 29, 2018 20:33:15 GMT 1
Oeb , the extended chain adjusters are very wide, and I know i have to get the sprocket carrier and caliper carrier milled down to fit, if it carnt be done then i will use the dt lc arm I already have, anybody know of someone with a milling machine near Sheffield?😉 The width across the spindle is not necessarily the issue, the problem comes when you fit the tyre & there is no room for the chain between tyre edge & frame tube. OEB
Post by 3tj6 on Apr 29, 2018 20:49:11 GMT 1
Oeb , I know what you mean about clearance,but mike027 has done it with a dt lc swingarm,fzr runs a 160 tyre, but could use a 150 instead and use a 428 chain instead of a 520 for a bit more clearance? Any advice is more than welcome tia Jon 😉
Post by donkeychomp on Apr 29, 2018 20:57:43 GMT 1
2MA should go in ok, only a 120 section tyre as standard.
Post by lb on Apr 30, 2018 2:14:01 GMT 1
Been searching for one for ages....
