Post by earthman on Apr 26, 2018 20:41:17 GMT 1
On a standard 350LC, anyone know what the speedo should read at X revs whilst in X gear?
Post by Deleted on Apr 26, 2018 20:44:50 GMT 1
y
Post by JonW on Apr 27, 2018 0:00:46 GMT 1
surely X revs in Y gear = Z mph?
Post by Deleted on Apr 27, 2018 7:49:26 GMT 1
TBH it’s a six speed gearbox it redlines probably somewhere in the region of 9000rpm
If you want every 1000 rpm in each of the gears that’s 54 different speeds, double that for every 500 rpm, quadruple for every 250 rpm
Try writing them all down whilst riding, it won’t be easy, or you have to stop at least 54 times and memorise what your speed was in that gear at the revs chosen
I guess you could work it out mathematically, the crank turns once every 0.06 seconds at 1000 rpm, look at the crank gear ratio that drives the gearbox (thats the gear cog at the end of the crank), factor in each of the 6 gear ratios to see how fast they will turn at 1000 rpm, multiply by the final drive ratio, which will vary with what drive cogs you are using front and rear, do that 54 times from 1000 to 9000 rpm and you’ll have your answer
Easy as pie or should that be Pi
Much too complicated for me though
Post by Deleted on Apr 27, 2018 7:56:34 GMT 1
5th gear 1000rpm for every 10mph Ish 5th gear 6000rpm = 70mph ish
Post by earthman on Apr 27, 2018 7:59:40 GMT 1
TBH it’s a six speed gearbox it redlines probably somewhere in the region of 9000rpm If you want every 1000 rpm in each of the gears that’s 54 different speeds, double that for every 500 rpm, quadruple for every 250 rpm Try writing them all down whilst riding, it won’t be easy, or you have to stop at least 54 times and memorise what your speed was in that gear at the revs chosen I guess you could work it out mathematically, the crank turns once every 0.06 seconds at 1000 rpm, look at the crank gear ratio that drives the gearbox (thats the gear cog at the end of the crank), factor in each of the 6 gear ratios to see how fast they will turn at 1000 rpm, multiply by the final drive ratio, which will vary with what drive cogs you are using front and rear, do that 54 times from 1000 to 9000 rpm and you’ll have your answer Easy as pie or should that be Pi Much too complicated for me though Thanks, best reply so far but that's way to complicated for me too. Lol I were thinking of one or two figures only, for example, cruising at 6000 revs in top gear on a flat road generally gives X mph on the speedo.
Post by Deleted on Apr 27, 2018 9:38:28 GMT 1
In top gear off the top of my head and in KM's. At 4000rpm I'm doing approx 80 kmph. At 5000 rpm i'm doing approx 100 k's.
Post by Deleted on Apr 28, 2018 5:35:31 GMT 1
Sorry, I'll change it abit. I must of been in fifth gear. So today in top gear at 4000 RPM , is was doing 88kmph . So close to 50mph and thats with standard gearing .
Post by bare on Apr 29, 2018 4:57:29 GMT 1
Small Factiod I've tripped over in the past: Yama Tachos are erm 'incorrect'... weren't great brand new, Decades on they can be laughably off (seen 1500 rpms error on one of mine). Ditto for the Speedo Insert a digital Spark pulse/rmp readout and using your Phone's GPS readout (tape the phone to the Tank?) then see what is Actually happening and at what Real road speed.
Post by earthman on Apr 29, 2018 8:31:27 GMT 1
Good points there Bare.
Post by Deleted on Apr 30, 2018 1:29:51 GMT 1
I cant say how accurate the tacho is on my bike but I believe the speedo is pretty close. Around here they have LED signs that flash up your speed if you are going over the speed limit and if your under it a green smiley face. Whenever I come across one I give it a little throttle to wipe the smile of its face and my speed comes up in red . Its always spot on with all the different ones Ive come across.
Post by earthman on Apr 30, 2018 7:31:39 GMT 1
I cant say how accurate the tacho is on my bike but I believe the speedo is pretty close. Around here they have LED signs that flash up your speed if you are going over the speed limit and if your under it a green smiley face. Whenever I come across one I give it a little throttle to wipe the smile of its face and my speed comes up in red . Its always spot on with all the different ones Ive come across. That's a good tip.
