Post by allspeeds on Apr 22, 2018 13:34:56 GMT 1
Hi what would need changing in 31k carbs to use them instead of 1ua powerjets on an F2 What would be a good place to start with jets etc ? Thanks
Post by trappena on Apr 22, 2018 14:54:34 GMT 1
Hi what would need changing in 31k carbs to use them instead of 1ua powerjets on an F2 What would be a good place to start with jets etc ? Thanks If the oem airbox and exhaust is used you can run them as is, provided the 31k jetting is still oem. If in doubt order a carb rebuilt kit from norbo for the 31k carbs so you know the correct jetting is used. Cheers
Post by allspeeds on Apr 22, 2018 17:12:55 GMT 1
Hi what would need changing in 31k carbs to use them instead of 1ua powerjets on an F2 What would be a good place to start with jets etc ? Thanks If the oem airbox and exhaust is used you can run them as is, provided the 31k jetting is still oem. If in doubt order a carb rebuilt kit from norbo for the 31k carbs so you know the correct jetting is used. Cheers Thanks the 31k carbs have stock jets in them good to go.
