Post by marsbar350 on Apr 20, 2018 19:25:40 GMT 1
Got to the stage of needing a clutch for my hybrid.us forks n clip ons.any suggestions on a suitable cable to use?
Post by midlifecrisisrd on Apr 20, 2018 19:38:00 GMT 1
There are genuine f2 cables on ebay just now for £18
Other option is maybe an early r6 cable
It has an adjuster at the clutch end which you can bolt up instead of the unadjustable wire clip
Post by Yogi on Apr 20, 2018 19:41:26 GMT 1
Jm9999dog on eBay has got nos ones for £18 +post If not try a yzf125r cable it's a bit longer and a nos one is only about £15 with an extra adjuster in the middle
Matt
Post by marsbar350 on Apr 20, 2018 19:41:35 GMT 1
When you mean early is that a 5eb ?
Post by midlifecrisisrd on Apr 20, 2018 20:41:19 GMT 1
When you mean early is that a 5eb ? Not sure 98on rings a bell Check out the used ones on ebay Steve
Post by marsbar350 on Apr 20, 2018 21:07:23 GMT 1
When you mean early is that a 5eb ? Not sure 98on rings a bell Check out the used ones on ebay Steve ive ordered a 5eb r6 one off the bay see how things go thanks everybody
Post by plumma on Apr 21, 2018 9:13:31 GMT 1
Did you have to shorten the R6 inner cable as it seems to long with my application.
Post by Tobyjugs on Apr 21, 2018 9:52:51 GMT 1
I used a cable from a FZ or FZR 600 and it was a good fit. The clutch perch is from a 1998 R6
