Post by pistanbroke on Apr 19, 2018 22:54:05 GMT 1
This has come up on the R1 forum , Bike belongs to a members cousin, looks like a California rz350 , has different pipes, probably as originals are heavily restricted , looks all there though , I’m debating having a punt on it , assuming the price allows for the inevitable rebuild spend , what you all reckon ?
Post by JonW on Apr 19, 2018 23:04:07 GMT 1
The pipes are Spec2'sI think.
Post by pistanbroke on Apr 19, 2018 23:05:53 GMT 1
The pipes are Spec2'sI think. Was the restriction in the standard pipes? Are the carbs restricted as well ?
Post by JonW on Apr 19, 2018 23:09:01 GMT 1
Cali std pipes have cats i think. A hot trick back in the day was to buy Canadian OEM pipes, which are like the ROW, ie no cats or smog stuff in em.
Carbs are single pull like all USA and Japanese stuff is. Can convert to twin pull with diff carbs (PWKs perhaps) and ROW cable, but basically I dont think they are restricted as such for Cali.
Post by Yogi on Apr 19, 2018 23:48:57 GMT 1
I'd go for that Don if cheap enough Complete bikes are getting fin on the ground now If you can get it for 2k or less you can't loose really nowadays
Keep us posted on ya progress.
Matt
Post by donkeychomp on Apr 19, 2018 23:49:48 GMT 1
Seat looks a bit odd. Screen does too. It's either very dusty or needs a respray and yes, then there is the cost of an engine rebuild. Contact the seller I say and see what is the least he would take for it.
Post by Yogi on Apr 19, 2018 23:51:12 GMT 1
Looks like the original pipes are laying beside the bike in the second pic
Post by srhiskx on Apr 20, 2018 4:31:06 GMT 1
Those are DG pipes. Bad toomey copies. Silencers are riveted on and always come loose.
Post by srhiskx on Apr 20, 2018 4:50:49 GMT 1
Windscreen is a stock one, different bars. Looks like a Corbin seat. Prices here in the US are sky high on RZ's. I wouldnt be surprised to see it go for 4,000-5,000 dollars.
Post by pistanbroke on Apr 20, 2018 6:56:46 GMT 1
Windscreen is a stock one, different bars. Looks like a Corbin seat. Prices here in the US are sky high on RZ's. I wouldnt be surprised to see it go for 4,000-5,000 dollars. Thanks for the input guys , the lad is going to his aunts to check out the tank , compression etc for me , I’ll keep youse posted 👍
