Post by petehodges on Feb 5, 2009 23:39:53 GMT 1
hi all ,just a quicky could you tell me the best way too set my power valves up please, looked at the manual but just making sure!! cheers pete
Post by Norbo on Feb 6, 2009 9:59:14 GMT 1
after fitting the cables turn the ignition on and it will fined its place then ajust the cables untill the long bit that sticks up with the small cut out is over the holl at the back . then do the ignition again and see that its still lined up if so do the locking nuts and your done .
Post by petehodges on Feb 6, 2009 15:52:00 GMT 1
thanks norbs but i stripped them and put them back in how can you tell if open or shut
Post by Norbo on Feb 6, 2009 15:57:59 GMT 1
look up the port they have to match up with the cut out on the nylon cable hold any way so they cant be to far out . well unless you put them in upside down
Post by Tone on Feb 7, 2009 22:00:16 GMT 1
To check you have the cables connected right if you look by the pulley of the servo there is marked 1 and 2 where the cables go and on the powervalve cover housing where the cable adjusters go this is also marked 1 and 2.Then as Norbo has said turn on the ignition but don't start the engine and the powervalves will cycle then check you can get a 4mm drill bit through the U part of the pulley into the hole behind the pulley. If not adjust cables accordingly.Turn off and on ignition to double check ( make sure you take out the drill bit first ) and make sure you have a small amount of freeplay in the cables. To make sure the powervalves are not 180 degrees out if you look at the valve joint between the barrels the two screw heads should be uppermost.Hope this helps .Tone.
