Post by earthman on Apr 9, 2018 22:30:56 GMT 1
Post by steve h on Apr 9, 2018 22:33:38 GMT 1
Just anneal the old one...costs nowt. Never had one leak yet that I've recycled.
Post by JonW on Apr 9, 2018 22:40:34 GMT 1
new washers are cheap, about 46 cents from the USA as a honda part fits our drain bolts.
Post by arrow on Apr 9, 2018 22:52:22 GMT 1
I always used those metal washers with the integral rubber seal. Reusable loads of times. Halfords have them.
Post by stusco on Apr 10, 2018 7:26:06 GMT 1
I always used those metal washers with the integral rubber seal. Reusable loads of times. Halfords have them. We call them dowty seals
Post by earthman on Apr 10, 2018 7:37:15 GMT 1
I always used those metal washers with the integral rubber seal. Reusable loads of times. Halfords have them. I'll search for them next time I'm in my local store, any clues on packaging or size of the one for an LC (4LO) ?
Post by earthman on Apr 10, 2018 7:39:56 GMT 1
Just anneal the old one...costs nowt. Never had one leak yet that I've recycled. Good point, should do that with all my vehicles really,...do you just heat by colour or go by a certain temperature?
Post by arrow on Apr 10, 2018 7:46:04 GMT 1
I always used those metal washers with the integral rubber seal. Reusable loads of times. Halfords have them. I'll search for them next time I'm in my local store, any clues on packaging or size of the one for an LC (4LO) ? I can't remember the size, it was a while back and I don't ride or own a bike anymore.
Post by earthman on Apr 10, 2018 7:47:16 GMT 1
No worries Gary.
Post by dusty350 on Apr 10, 2018 7:53:19 GMT 1
The Yamaha washer for the sump plug is over £6 !! Get the Honda part- same fit and works perfectly. Fowlers stock them - last time I bought one it was 59p. Part number 94109 14000. Dusty
Post by JonW on Apr 10, 2018 8:18:48 GMT 1
Yes thats the ones I get Dusty, US$0.41 if youre buying something else from the USA OEM suppliers just add a few to your cart.
Post by Tobyjugs on Apr 10, 2018 11:57:47 GMT 1
You can heat your copper washer up until it's cherry red and quench it in water or just clean the parts and use a drop of Loctite 542
Post by Deleted on Apr 10, 2018 14:56:55 GMT 1
M14 x 18 copper washer aren’t they or 20mm outside
Just confirm and I’ll get us some, let me know how many
You’ll know where from
Post by copper99 on Apr 10, 2018 20:58:31 GMT 1
Hold on, the ad is not for a re-useable sump plug *washer*, its for a re-useable sump plug.....as if the original item must be thrown away after use..!
As for the washers, a pack is handy and costs a few quid from eBay, making each one a few pence..
Post by earthman on Apr 10, 2018 21:00:46 GMT 1
Hold on, the ad is not for a re-useable sump plug *washer*, its for a re-useable sump plug.....as if the original item must be thrown away after use..! Good point. Lol
Post by copper99 on Apr 10, 2018 21:06:22 GMT 1
Hold on, the ad is not for a re-useable sump plug *washer*, its for a re-useable sump plug.....as if the original item must be thrown away after use..! Good point. Lol ...and the organic coating lasts for exactly the same amount of time as your eBay checkout payment goes through...what a load of bollox.
Post by bare on Apr 10, 2018 21:56:16 GMT 1
Small point :-) It' the Transmission oil we are fitting a plug to... NOT the engine. How often does the Trans oil need changing? Not very often at all IF one follows Yamas schedules
Post by earthman on Apr 13, 2018 7:10:15 GMT 1
Small point :-) It' the Transmission oil we are fitting a plug to... NOT the engine. How often does the Trans oil need changing? Not very often at all IF one follows Yamas schedules I've just been looking for the scheduled oil change in the Haynes manual, it's listed under the 3 monthly/2000 miles section. That's more often/sooner than I thought,....is that right??
Post by earthman on Apr 13, 2018 7:33:19 GMT 1
It can also be found listed on page 20, within that whole chart/diagram,...the print is rather small.
Post by Tobyjugs on Apr 13, 2018 10:19:29 GMT 1
There is no oil filter so if it's used and abused all your small clutch plate particles and other worn particles keep circulating in the oil until they settle in the bottom of the engine
Post by earthman on Apr 13, 2018 14:03:53 GMT 1
There is no oil filter so if it's used and abused all your small clutch plate particles and other worn particles keep circulating in the oil until they settle in the bottom of the engine Good point, best to drain/replace frequently then.
Post by Tobyjugs on Apr 13, 2018 15:33:20 GMT 1
There is no oil filter so if it's used and abused all your small clutch plate particles and other worn particles keep circulating in the oil until they settle in the bottom of the engine Good point, best to drain/replace frequently then. Depends how many litres of 2stoke oil you use😂🤣😂🤣
Post by earthman on Apr 13, 2018 19:59:27 GMT 1
Good point, best to drain/replace frequently then. Depends how many litres of 2stoke oil you use😂🤣😂🤣 It's highly unlikely that I'll do 2000 miles in 6 months let alone 3 but according to them I should be draining/replacing it.
