Post by johnnytheboy on Apr 6, 2018 7:34:55 GMT 1
Hi all to elsie fans Just checking whats the best ngk spark plugs ,ie heat grade, iridium or not .Its a 350lc 4lo with short can allspeeds what you lads and lasses using thanks
horace
Post by horace on Apr 6, 2018 7:38:20 GMT 1
I use 8 or 9 never really noticed any great difference , none resistor type with rubber caps , sick of those Ngk plastic ones breaking.
Post by earthman on Apr 6, 2018 8:03:37 GMT 1
+1 on the non resistor type, the Haynes manual only states the '8'so I've stuck with that.
Post by donkeychomp on Apr 6, 2018 21:26:54 GMT 1
Make sure you get a real one. More fakes than genuine out there. There is a Youtube video of it...the boxes are different
Post by earthman on Apr 7, 2018 8:14:31 GMT 1
Make sure you get a real one. More fakes than genuine out there. There is a Youtube video of it...the boxes are different Alex Very good point, easy to forget that there are fakes of such a cheap item in the first place.
Post by mattybeckett on Apr 8, 2018 21:18:40 GMT 1
I use 9s as they run a little bit cooler.
Post by johnnytheboy on Apr 9, 2018 7:54:28 GMT 1
so are non resistor type plugs better and if so why
Post by muttsnuts on Apr 9, 2018 8:29:13 GMT 1
gives a slightly better spark as no resistor for the electricity to go through (6ohms less normally), plus if you are using resistor caps and plugs, that can add up to 10+ohms, which is a lot of energy being wasted. We don't need resistor plugs or caps these days, we had them back in the day as the signal from the spark plugs interferred with the old analogue radios and TV's, no such problem these days
Post by johnnytheboy on Apr 9, 2018 8:44:39 GMT 1
so we are looking at a B8 or B9ES NGK plug and what is the number for the cap mate.
Post by copper99 on Apr 9, 2018 19:58:29 GMT 1
Slightly off topic to this but when 1 knackered cap was swapped on the dyno session on my 500, the trace became much smoother and the bike gained 1.5bhp...
I also have short can allspeeds on my 350 and followed some here Dave put up yonks ago, removed the snorkel and upjetted it, ran much better...still on the standard plugs thou(8s)
Post by johnnytheboy on Apr 10, 2018 7:49:21 GMT 1
I ordered B9ES and NGK LZFH NON Resistor Spark Plug Caps.So have you removed the snorkel exiting the airbox and what carbs are you using.I am running mine on 31K carbs great advice from stan stevens when I picked up my rebuilt engine they virtually eliminate that flat spot The 4LO carbs had.If you bought classic motorcycle meachanics mag november 2017 you will see a full 2 page article on my Elsie restoration.
Post by donkeychomp on Apr 14, 2018 23:24:13 GMT 1
Johnny (nice Mad Max name lol) I've been looking for those plug caps and they all state they are for old British bikes. And they are all black! Is the NGK code correct? If so where did you get yours from?
Cheers, Alex.
Post by donkeychomp on Apr 14, 2018 23:57:24 GMT 1
Post by johnnytheboy on Apr 15, 2018 5:46:31 GMT 1
Johnny (nice Mad Max name lol) I've been looking for those plug caps and they all state they are for old British bikes. And they are all black! Is the NGK code correct? If so where did you get yours from? Cheers, Alex. Hiya donkeychomp yes that code is correct and they are on my Elsie now .I bought them from the green sparkplug website along with caps and plugs for other bikes
Post by johnnytheboy on Apr 15, 2018 5:48:03 GMT 1
Johnny (nice Mad Max name lol) I've been looking for those plug caps and they all state they are for old British bikes. And they are all black! Is the NGK code correct? If so where did you get yours from? Cheers, Alex. Hiya donkeychomp yes that code is correct and they are on my Elsie now .I bought them from the green sparkplug website along with caps and plugs for other bikes They are for any bike just with no resistor
Post by donkeychomp on Apr 15, 2018 10:59:56 GMT 1
Cool. Thanks mate.
Post by Deleted on Apr 15, 2018 11:05:02 GMT 1
Not sure what normal life expectancy is with 2t bikes. But I just removed my 8's after about 4000 km's. They still look that good that I put them in my project bike to run it in with. Were to good to turf out.
Post by reedpete on Apr 15, 2018 15:44:19 GMT 1
I’ve got some leads with integrated caps you could use, (actually I have about 300 sets of various types at my place...don’t ask !) not perfect but would do the trick...so check with your mates before you go buying stuff! otherwise the black screw on NGK caps are very useful.
Post by donkeychomp on Apr 15, 2018 20:44:05 GMT 1
Sending a PM
