Post by dangerousal on Apr 2, 2018 18:48:50 GMT 1
Hi does anyone know off hand the sizes for the water pump and oil pump bearings...thanks in advance!
Post by oldelsieboy on Apr 2, 2018 18:55:31 GMT 1
Hi does anyone know off hand the sizes for the water pump and oil pump bearings...thanks in advance! Water pump bearing is B6300Z = 10 x 35 x 11. There is no oil pump bearing. OEB
Post by dangerousal on Apr 2, 2018 19:41:14 GMT 1
Sorry should have qualified on 31k engine!
Post by dusty350 on Apr 2, 2018 19:44:01 GMT 1
Still no oil pump bearing on a Pv engine. Dusty
Post by dangerousal on Apr 2, 2018 21:42:29 GMT 1
Excellent...thanks for the information...
Post by arrow on Apr 3, 2018 0:17:44 GMT 1
Yes, the 10mm bore of the oil pump is the main (plain) bearing. Sometimes it's knackered requiring a replacement casting.
Post by jon on Apr 3, 2018 9:51:20 GMT 1
Yes, the 10mm bore of the oil pump is the main (plain) bearing. Sometimes it's knackered requiring a replacement casting. I thought the oil pump ‘bearing’ as such was referred to as a ‘metal worm shaft outer 1371317600’. Whilst not strictly a bearing such as a ball bearing, is this not what supports the shaft? Jon
Post by arrow on Apr 3, 2018 10:03:34 GMT 1
You are correct, but they are separate part numbers Jon. I was referring to the actual pump itself which has its own part number.
Post by dangerousal on Apr 3, 2018 18:21:45 GMT 1
Thanks guys...as always the knowledge and feedback on this forum is excellent
