Post by Tobyjugs on Mar 27, 2018 23:24:58 GMT 1
I have learned today that i will be very busy for the next couple of months. I had planned to open up the top end of the engine on my bike and measure every thing before i go to Autodrome de Linas-Montlhéry to blast round the circuit or have a go at sprint races. I wont have enough time as i also have to prepare the other bike for The Rockanje Classic TT for Kees.
My plan is to take the pipes off and check the blow by colour around the piston rings and measure it on the dyno. I'm not much of a fan for a compression test as the oil in the fuel can influence the readings (in my opinion)
Has anybody any other suggestions without a strip down?
Post by dusty350 on Mar 28, 2018 8:05:23 GMT 1
Leak down test for sure Dusty
Post by Tobyjugs on Mar 28, 2018 12:12:48 GMT 1
Yep I can do that.
Post by midlifecrisisrd on Mar 28, 2018 13:07:31 GMT 1
Scope in the plug holes to check the bores for scoring
Post by Tobyjugs on Mar 28, 2018 13:20:51 GMT 1
Good idea I can do it through the exhaust port as I do not have a flexible endoscope
Post by simon998 on Mar 28, 2018 13:42:07 GMT 1
Post by earthman on Mar 28, 2018 16:17:21 GMT 1
Aldi/Lidi stores sell a stand alone scope with monitor from time to time, cost around £30, I bought one the first time around, it's certainly come in handy.
Post by Tobyjugs on Mar 28, 2018 16:28:11 GMT 1
Thanks for your suggestions about the endoscope. Fate is just so strange. Tomorrow i have to do an endoscope inspection of the oil ways in a crank pin that has just been annealed after a big end bearing failure. i will post some pictures of the endoscope up later.
Post by Tobyjugs on Mar 28, 2018 17:13:34 GMT 1
Here's a quick tease. As you can see it's a 2 piece endoscope that comes in matching colours. I will post some more pictures later tonight after some work on the bike for Kees, but first some microwave food. AHH the joys of being a bachelor
Post by Tobyjugs on Mar 28, 2018 21:13:36 GMT 1
Ok i changed the cylinder head and Kees turned up so he got a short lesson in how to use an endoscope. Here he is looking like he knows what he's doing. Here are some pictures we made. The picture below shows the worst scratch i could find this is not so bad and an endoscope really magnifies the surfaces you are inspecting Below is a picture of the exhaust port with the bottom part of the locked power valve Most of the cylinder walls on both cylinders look like this except for some scuffing above both exhaust ports.
I hope some of you find this interesting to see.
Post by wallcraft on Mar 28, 2018 22:29:01 GMT 1
Brilliant great pics, very interesting to see what's going on with out a full or partial tear down. Will have to see if I can get a cheapo one!!
Mark
Post by arrow on Mar 28, 2018 23:31:33 GMT 1
That motor looks in good condition. Scratches always look worse in a photo than they actually are.
Post by beardy on Mar 29, 2018 8:07:50 GMT 1
very interesting pictures tobyjugs. thanks i did not realise you are from holland. i was over in belgium last year on my lc for the john bull rally. sometimes we pop over the border into holland or germany.
Post by Tobyjugs on Mar 29, 2018 9:00:11 GMT 1
If you go via Europoort you welcome to drop by and say hello if your travel plans are not too busy
Post by 4l04ever on Mar 29, 2018 17:31:59 GMT 1
You can use a compression tester on your engines too, to make sure the rings are sealing equally. You may need to put a little oil down the plug hole to get the rings to seal if doing from cold. If you record the values on your new engine builds, you can keep a record as you go to see how much wear you have and that it is even, and also make sure you are not getting too much blow by.
Post by 4l04ever on Mar 29, 2018 17:35:40 GMT 1
....just thought.....while you have the endoscope, you could get Kees to check your prostate gland..... ;-)
Post by Tobyjugs on Mar 29, 2018 20:13:34 GMT 1
....just thought.....while you have the endoscope, you could get Kees to check your prostate gland..... ;-) Ha ha, the first thing i did was shove it up me nose and he was not impressed (Dutch humour is not quite the same as ours). If did your suggestion he would probably be traumatised. I would not like to try and explain that to his mother
Post by beardy on Apr 4, 2018 7:18:01 GMT 1
thanks for the invite (:
