Post by donkeychomp on Mar 6, 2018 23:44:00 GMT 1
Does anyone know if there is a width difference between a 350YPVS rear caliper and a TZR250 one? Examining pictures I've found the only difference I can see is that the bleed nipples are mounted in other positions. I'm asking as I have a PV caliper and a TZR that needs a rear brake!
Post by JonW on Mar 7, 2018 0:11:20 GMT 1
The ypvs had 2 types of caliper on the ypvs, the later models use the same caliper as the fronts but with different nipple orientation. Same caliper was used on some Kawasakis as fronts etc
Post by donkeychomp on Mar 7, 2018 2:07:56 GMT 1
Thanks Jon but my question still stands. Is there a width difference? My PV one mounts straight onto the TZR mount but when I go to mount the wheel it's too wide, by about 3mm. Now wondering if I have the correct sprocket carrier!
Post by andy748 on Mar 7, 2018 20:35:16 GMT 1
Hi Alex, Have valve front fitted to my kitchen build special on the rear, TZR caliper and Belgarda wheel (Same hub casting and sprocket carrier as TZR, had to shim it across with stainless washer to get alignment spot on, mine is mounted on a F2 swinger. Check the pictures out. Andy. SAM_3159 by Andrew Jolly, on Flickr SAM_3202 by Andrew Jolly, on Flickr
Post by donkeychomp on Mar 7, 2018 22:19:35 GMT 1
Thanks for the pics Andy. Not sure where I'm going wrong but I'll have another go at this tomorrow!
