Post by bezzer on Mar 6, 2018 14:25:29 GMT 1
Hi Lads, Any idea what the wear limit should be for the steel clutch plates on a 350 4L0?. Checked for warpage & all good. I’m at work so no access to a manual! 😬
Cheers bezzer
Post by earthman on Mar 6, 2018 22:49:32 GMT 1
Service limit is 2.7mm I believe.
Post by shaunyb63 on Mar 7, 2018 0:53:01 GMT 1
I just got some genuine Yamaha steel plates from norbo and they measure 1.18mm, don’t know what the wear limit is though, the friction plate wear limit is 2.7mm.Hope this helps.
Post by bezzer on Mar 7, 2018 6:50:02 GMT 1
I just got some genuine Yamaha steel plates from norbo and they measure 1.18mm, don’t know what the wear limit is though, the friction plate wear limit is 2.7mm.Hope this helps. Thanks chaps, Yes it’s the steel plate measurement I need, mine are all around 1.16 to 1.18, so perhaps not too badly worn?. There is no distortion or ‘blueing’ so may be reusable. Out of interest would you lightly scotchbrite the faces to aid bedding in of the new friction plates?. Many thanks bezzer
Post by bare on Mar 7, 2018 23:23:58 GMT 1
IF the steels are not visibly Blued, Ridged or Warped they are good. Rare to have to replace oem Yama steels.
Post by bezzer on Mar 8, 2018 10:32:59 GMT 1
IF the steels are not visibly Blued, Ridged or Warped they are good. Rare to have to replace oem Yama steels. Thanks Bare, They’re not warped or have any evidence of heat cycle. Would it be beneficial to scotchbrite the faces to aid bedding of the new friction plates?. Many thanks bezzer
Post by Tobyjugs on Mar 8, 2018 12:29:20 GMT 1
I took a set to work and cleaned them with a very fine blaster (used for cleaning fuel injector parts). These were a little rusty. when fitted I did not notice any difference. Maybe it would make a difference with a powerful engine until they bed in.
