Post by wangwang on Mar 1, 2018 17:03:50 GMT 1
I'm trying to fit a new stator wiring grommet thingy.
I assume you release the wires from the connector plugs, but can't see how they come out, help please!
cheers wang
Post by Bertie Wooster on Mar 1, 2018 19:37:03 GMT 1
I use a small flat screw driver to prise out of block
Post by Mr Kipling on Mar 2, 2018 2:39:06 GMT 1
Post by JonW on Mar 2, 2018 4:10:42 GMT 1
I have the same set, but with 3 'wheels'. I bought it for cheap on amazon, great stuff but still these wires fought me :/
Post by wangwang on Mar 2, 2018 12:45:58 GMT 1
Is it a thin flat one you need? as I can't see the rang to release the terminal.
Post by spacejunkie on Mar 2, 2018 18:24:04 GMT 1
I give up I couldn’t do it
Post by JonW on Mar 2, 2018 22:58:18 GMT 1
the round ones are for round connectors, flat ones for straight. I almost gave up on mine, but finally i started to understand how they worked and got them. they were a bugger tho.
Post by wangwang on Mar 2, 2018 23:16:32 GMT 1
I've ordered one of those little gizmos, be worth it in the long run. cheers.
Post by spacejunkie on Mar 2, 2018 23:20:16 GMT 1
I completely rebuilt Me lc from the ground up with help from some good people but that defeated me
Post by wangwang on Mar 17, 2018 21:32:49 GMT 1
Worked spot on, new rubber now fitted. Cheers Guys
Post by Tobyjugs on Mar 18, 2018 10:21:18 GMT 1
For a while i used a piece of flattened copper wire until i needed to do the round ones, then i bought the tools as well.
Post by dereckerick on Mar 20, 2018 18:43:42 GMT 1
Worked spot on, new rubber now fitted. Cheers Guys Where did you get the new rubber sleeve/grommet?
Post by wangwang on Mar 20, 2018 19:52:38 GMT 1
Post by dereckerick on Mar 21, 2018 4:50:19 GMT 1
I'd looked....but there it is!! Im sure ive said that before.......
