Post by philmill on Feb 26, 2018 17:00:41 GMT 1
Just a quick question, are 31k seat catches the same as 4L0?
Thanks, Phil
Post by yamman1066 on Feb 26, 2018 17:57:46 GMT 1
no
Post by earthman on Feb 26, 2018 18:08:51 GMT 1
I thought that they just had longer levers but would still fit on a 4LO or is that from another model??
Post by philmill on Feb 26, 2018 19:08:45 GMT 1
Looking at pics they look very similar, that why I asked. Might be fun trying to find a pair then!
Phil
Post by rich on Feb 26, 2018 21:14:49 GMT 1
Basically the same and are interchangeable but the 31K ones have longer levers and the helmet loop is longer too. It's because the LC catches are exposed and the 31K ones are up behind the side panels.
Post by philmill on Feb 26, 2018 21:38:36 GMT 1
Thanks Rich, so useable at least. Phil
Post by midlifecrisisrd on Feb 26, 2018 23:20:57 GMT 1
On my last build I used LC ones but fitted ypvs levers
Post by Shytalk on Feb 26, 2018 23:55:09 GMT 1
Are you looking for 31K seat catches ?
Post by philmill on Feb 27, 2018 10:04:40 GMT 1
Shytalk, yes mate, I need a pair, PM me if you have some. thanks.
Post by LC_BOTT on Feb 27, 2018 11:28:45 GMT 1
Post by philmill on Feb 27, 2018 12:55:19 GMT 1
I never realised they were the same, well similar... I would want to lock seat I think.
Post by JonW on Feb 27, 2018 23:03:07 GMT 1
Worth noting perhaps for completeness that the tang thats slips into these catches is different on the LC and ypvs.
Post by philmill on Feb 28, 2018 10:42:23 GMT 1
Thanks Jon, good info!
Post by earthman on Feb 28, 2018 12:03:03 GMT 1
I never realised they were the same, well similar... I would want to lock seat I think. Whichever ones you do end up with, make sure that the lock actually works correctly all the time,....I discovered that mine could release itself after popping the one on the opposite side. I've fixed mine now, I guess it's all down to 30+ years of wear basically, a bit too much play between the pivot/cam/heel of the release lever is the cause of the problem.
Post by philmill on Feb 28, 2018 22:41:54 GMT 1
Good tip, thanks.
Post by scooter on Apr 29, 2018 20:42:33 GMT 1
I didn't realise that the lock was for the seat I thought it was just for the helmet lock I've just put my seat on my rebuild and the levers work without a key looks like something else to check and repair you learn something new on here everyday
