Post by rigga on Feb 27, 2018 0:07:54 GMT 1
Black painted for me too
Post by shaunthe2nd on Feb 27, 2018 23:41:29 GMT 1
Have you thought about making the indicator tube mount from that is welded to the rear sub-frame of 250/350LC, and usually cut off? Someone does them on ebay from time to time for about 32 quid plus delivery which is a bit steep. If you could do them for something like 15 quid too I reckon you would get a few takers. Quite possibly, would need someone to take some very accurate measurements of all aspects from an original. Anyone willing and able to do this? I might have to start some new threads soon, I think lol I went in my garage to measure up my the said tube on my spare rear sub-frame only to find that the little 'tangs' for the indicator rubber sleeves are missing so can't be sure if mine is original or has been modified at some point. I'm hoping that someone else has a spare original they can measure up. Sorry. Still interested if you can make them though.
Post by dono on Mar 2, 2018 19:56:30 GMT 1
Is it a goer for the horn brackets?
Post by sp885 on Mar 2, 2018 20:12:29 GMT 1
Just picked up on this thread, I'd be interested in a black painted one please
Cheers Steve
Post by wangwang on Mar 2, 2018 23:14:15 GMT 1
I'd have a couple, one of each.
Post by tippo on Mar 2, 2018 23:56:07 GMT 1
Mild Steel for me please
Post by risolc on Mar 4, 2018 15:30:36 GMT 1
Put me on the list if they go ahead. Black paint please. Dave
Post by jackjabba on Mar 4, 2018 15:47:42 GMT 1
I will take 2 in mild steel.
Post by 0h5h1t on Mar 15, 2018 21:24:42 GMT 1
oh go on then. if it helps, I'll have a stainless one.
Post by loctite on Mar 15, 2018 21:25:42 GMT 1
two mild steel please
rickymac
Hi all new to this forum and owner of a barn find 250lc
Post by rickymac on Mar 27, 2018 14:41:36 GMT 1
Put me down for a mild steel one
Post by spacejunkie on Apr 21, 2018 16:33:04 GMT 1
How is the going at the mo come on there must be a few people that need one
Post by robin on Apr 30, 2018 17:04:51 GMT 1
I need one in Black please...
Post by oldelsieboy on Apr 30, 2018 17:33:50 GMT 1
Looks like elsiefreak who offered to make the brackets has bailed & is no longer a member.
OEB
Post by dono on Apr 30, 2018 17:52:54 GMT 1
Looks like elsiefreak who offered to make the brackets has bailed & is no longer a member. OEB Balls! I saw a thread on face book were some guy had just drilled and tapped the bottom yoke same pitch as the readily available plastic yoke cover and used a couple of spacers on each side with the standard flat horn bracket in between the two spacers, if that makes sense? I’m going to look st doing that, bought most of the stuff, just need to see if I will have the bike to do it as p,an I g on sending it to Mutts after seizing it on Sunday.
Post by robin on Apr 30, 2018 18:06:00 GMT 1
Looks like elsiefreak who offered to make the brackets has bailed & is no longer a member. OEB Balls! I saw a thread on face book were some guy had just drilled and tapped the bottom yoke same pitch as the readily available plastic yoke cover and used a couple of spacers on each side with the standard flat horn bracket in between the two spacers, if that makes sense? I’m going to look st doing that, bought most of the stuff, just need to see if I will have the bike to do it as p,an I g on sending it to Mutts after seizing it on Sunday. Well that's just typical, I thought I had just found a pattern one to for £16, then the guy is not trading at the moment! Will look at how to mount a single horn without one.
Post by dusty350 on May 1, 2018 7:35:09 GMT 1
Post by robin on May 1, 2018 10:14:38 GMT 1
Did you only get one made?
Post by Deleted on May 1, 2018 10:53:42 GMT 1
I'd guess Dusty made that himself. As he said. Easy . Bit of patience and worst case scenario you start again if you get a bit eager cutting.
Post by Deleted on May 1, 2018 10:55:23 GMT 1
By the way Dusty. Just that little bit of bike in the piccy suggests its a work of art. NICE.
Post by dusty350 on May 1, 2018 17:40:11 GMT 1
Hi Cheers Ken😉 Yea, I only made 1 coz i needed it for the orange hybrid. The white hybrid has an lc bracket fitted so i took that off and drew round it on some card from a cereal box. Cut out the shape from the card then drew round that on some steel plate i had knocking around. Cut it out with a jigsaw with a metal blade fitted and then dressed all the edges with a fine file. My engineering guy charged me £2 to put it on his brake press and put the angle in it. Think i may still have the card template somewhere if you fancy having a go 😉
Dusty😁
