Post by philmill on Feb 21, 2018 17:33:24 GMT 1
Hi Guys, anybody got any tips for removing the needle rollers from a RGV Banana swinging arm? the ones on the main bolt look bad but the ones on the recessed pivot look impossible! I managed to remove the rusted spacer from the shock pivot so will be looking for all the pivot bolts etc.
Phil
Post by steeley on Feb 21, 2018 19:37:09 GMT 1
Hi I have had luck with an anchor bolt.
Post by 4l04ever on Feb 21, 2018 21:17:31 GMT 1
A blind bearing puller with a slide hammer attachment might get them out....
May need penetrating fluid (PlusGas) and/or heat too.
Post by kostas on Feb 21, 2018 22:09:12 GMT 1
Done this recently. A blind bearing puller is the real tool but as they can be expensive I used a steel anchor bolt. Once you expand the bolt in the needle bearing take a long rod and a heavy hammer and drive it out from the opposite side.
If you have access to a hydraulic press then things get easier and more civil.
Kostas
Post by philmill on Feb 22, 2018 10:56:21 GMT 1
Thanks guys, so an anchor bolt it is!
Phil
Post by Deleted on Feb 22, 2018 11:43:03 GMT 1
Torpedo7 blind bearing remover
Very simple and very effective
Post by stusco on Feb 22, 2018 17:58:19 GMT 1
Blind bearing puller cheap as chips on eBay
Post by philmill on Feb 22, 2018 20:40:40 GMT 1
Thanks guys, I bought the blinder bearing kit on eBay this morning. Seems a good deal, up to 57mm.
Phil
