Post by stusco on Feb 17, 2018 17:00:02 GMT 1
I just spent the afternoon trying to wash petrol away from the front of my garage after my leaky fuel tap filled the crank cases with petrol,I thought it was all out after running up and down the street with the plugs out but no !when it started it sprayed half the street with petrol ,the neighbors are not impressed,and it runs like shite it’s like the pilots it just bogs down when I tried to pull away
Post by midlifecrisisrd on Feb 17, 2018 18:25:43 GMT 1
Yep been there
It should eventually evaporate from the tarmac
As for the crap running, did you refit the vac pipe
Post by stusco on Feb 17, 2018 18:41:05 GMT 1
Yes the pipe is on but I’m not sure about it I’ve got better stuff on the way
Post by midlifecrisisrd on Feb 17, 2018 18:50:35 GMT 1
It will run like sh1t till all remains of fuel are out
You are lucky it didn't hydraulic lock and bend a rod or twist the crank
Post by stusco on Feb 17, 2018 20:39:13 GMT 1
I thought it was 86 again spending hours pushing and kicking a black lc2,the other thing I noticed is the Pv motor is chattering any thoughts on that
Post by rigga on Feb 17, 2018 20:54:39 GMT 1
Battery charged fully?
Post by stusco on Feb 17, 2018 20:59:41 GMT 1
It was charged a couple of weeks ago and is a cheap battery but has been zero degrees since I’ll try that tomorrow
Post by bare on Feb 18, 2018 22:15:18 GMT 1
More issues there than a Dodgy Tap methinks. IF the Carb float /needles were actually working there wouldn't be an engine full of fuel.
Post by earthman on Feb 18, 2018 22:46:51 GMT 1
IF the Carb float /needles were actually working there wouldn't be an engine full of fuel. I were about to say the same thing.
Post by stusco on Feb 19, 2018 8:21:59 GMT 1
Not impossible I only put the fuel in to check the tap it failed !,bought a new tap and found the engine/exhaust full of fuel.the carbs seemed fine when running on an external tank
