Post by bezzer on Feb 11, 2018 23:25:24 GMT 1
Pardon my ignorance, but does anyone know if the carb slides are the same across the Aircooled/LC range?, i.e. 250/350/400, presuming they all use the VM26 carb?. I’m in need of a pair of carb slides for my 350, tried the wanted section to no avail, so thought I’d widen the search criteria if the A/C slides were viable.
Thanks in advance bezzer.
Post by rigga on Feb 11, 2018 23:41:52 GMT 1
31k ypvs slides work in 4l0 Carb bodies
Post by bezzer on Feb 12, 2018 0:04:07 GMT 1
31k ypvs slides work in 4l0 Carb bodies Thanks rigga, another avenue to explore then 👍🏻
Post by Tobyjugs on Feb 12, 2018 0:39:26 GMT 1
I have been told that the cutaway in the slide can be different in theA/C carbs, but you can check this by looking at the marking on the underneath of the slide.
I have changed carbs in the past and never changed the top part so, screw top, spring and slide stay and i have just changed the bodies. this was for 4L0 01 and 31K carbs
Post by jon on Feb 12, 2018 8:45:23 GMT 1
Pardon my ignorance, but does anyone know if the carb slides are the same across the Aircooled/LC range?, i.e. 250/350/400, presuming they all use the VM26 carb?. I’m in need of a pair of carb slides for my 350, tried the wanted section to no avail, so thought I’d widen the search criteria if the A/C slides were viable. Thanks in advance bezzer. I can’t say for the entire AC range, as I am not familiar with them. However I do have a set of RD250 carbs to compare. From memory they are totally different. Larger diameter and possibly shorter. I think they are 28mm too. Jon
Post by bezzer on Feb 12, 2018 9:14:09 GMT 1
Pardon my ignorance, but does anyone know if the carb slides are the same across the Aircooled/LC range?, i.e. 250/350/400, presuming they all use the VM26 carb?. I’m in need of a pair of carb slides for my 350, tried the wanted section to no avail, so thought I’d widen the search criteria if the A/C slides were viable. Thanks in advance bezzer. I can’t say for the entire AC range, as I am not familiar with them. However I do have a set of RD250 carbs to compare. From memory they are totally different. Larger diameter and possibly shorter. I think they are 28mm too. Jon Thanks Jon, That would seem conclusive they are NOT interchangeable then, I appreciate your input, thanks too to Tobyjugs, I’ll have a look at the numbers under my 250lc’s slides and try to trace some that way. Thanks again for the replies/input lads. ATB bezzer
Post by 4l04ever on Feb 12, 2018 9:19:30 GMT 1
If you source 31K slides, make sure you get the cable clips, as they are not compatible with 4L0/4L1 clips.
Post by bezzer on Feb 12, 2018 9:42:43 GMT 1
If you source 31K slides, make sure you get the cable clips, as they are not compatible with 4L0/4L1 clips. Cheers Rob, More good info mate!, hadn’t realised there’d be a difference. To be honest no-one seems to want to part with any 4L0 ones, so finding 31K slides will be even more of a challenge I reckon ☹️ Cheers bezzer
Post by Tobyjugs on Feb 12, 2018 10:43:46 GMT 1
Get in touch with mutts he's probably dealt with the A/C carbs as well
Post by 4l04ever on Feb 12, 2018 10:54:34 GMT 1
AC carbs are 28mm...
Post by bezzer on Feb 12, 2018 11:18:49 GMT 1
Thanks lads, The A/C diameter is as Jon states larger then?. I’ll stick to 4L0/31K slides for my search then, unless the DT125/175MX uses VM26 carb?……
Post by simon998 on Feb 12, 2018 13:17:04 GMT 1
DT125 uses a VM24 (10v) from what I remember.
Post by bezzer on Feb 12, 2018 13:33:18 GMT 1
DT125 uses a VM24 (10v) from what I remember. Cheers Simon, just looked and the 175 MX also uses VM24, and interestingly has differing throttle slides between early and later models …… I’m not having much luck! Lol
Post by sbscnor on Feb 12, 2018 13:56:17 GMT 1
PM'd you
Post by jon on Feb 12, 2018 13:58:47 GMT 1
As I thought. They are parallel too, unlike the tapered LC and YPVS ones. Jon
Post by bezzer on Feb 12, 2018 15:41:51 GMT 1
Thanks Bud, just replied.
Post by muttsnuts on Feb 12, 2018 21:14:51 GMT 1
A/C slides are completely different, suitable slides for 4L0 are 4L1, 4L2, 31k, 1UA, 1WT, 3GG from memory, as you say, hard to find these days, I use to have loads, but sadly used them all fixing peoples carbs, stuck for a pair myself at the moment, you can still buy them new, but at £35 to £40 each, its a little off putting !!
You need to make sure the cutout is 2.0 and not 2.5 as well, its stamped underneath the slide
HTH
Post by bezzer on Feb 13, 2018 0:08:56 GMT 1
A/C slides are completely different, suitable slides for 4L0 are 4L1, 4L2, 31k, 1UA, 1WT, 3GG from memory, as you say, hard to find these days, I use to have loads, but sadly used them all fixing peoples carbs, stuck for a pair myself at the moment, you can still buy them new, but at £35 to £40 each, its a little off putting !! You need to make sure the cutout is 2.0 and not 2.5 as well, its stamped underneath the slide HTH Thanks for the comprehensive info Dave, hopefully sorted now, thanks to this brilliant forum and it’s members!. They say every day’s a school day, we’ll I’ve learnt some stuff today, that’s for sure! 😊
