Post by 4l04ever on Feb 12, 2018 11:03:10 GMT 1
Post by lcyoungboy on Feb 14, 2018 12:26:21 GMT 1
I just ordered the 1 that dusty put a link up to..for £15.99 delivered you cannot go wrong 👍.
I also had a legend kickstart..i think was £100 New ..and yes the thread pulled on it 1st time and I never even got to use it 🤔..tried to drill and tap but there not much to work with..must see if I can get someone to do a job on it and move it on.
Dave
Post by Yogi on Feb 14, 2018 18:15:35 GMT 1
I just ordered the 1 that dusty put a link up to..for £15.99 delivered you cannot go wrong 👍. I also had a legend kickstart..i think was £100 New ..and yes the thread pulled on it 1st time and I never even got to use it 🤔..tried to drill and tap but there not much to work with..must see if I can get someone to do a job on it and move it on. Dave Exactly the same as mine When I told them they blocked my eBay account Gotta love em,,,,NOT
Post by Yogi on Feb 14, 2018 18:18:15 GMT 1
I bought a couple of stainless ones but when they came they were chrome Let us know what you get Matt
Post by donkeychomp on Feb 14, 2018 21:40:08 GMT 1
Mine turned up today, it looks brilliant and is chrome. But widening it has me stumped, tried the hd screwdriver in it but I can't budge it!
Post by donkeychomp on Feb 14, 2018 22:19:15 GMT 1
tezrhc
Post by tezrhc on Feb 14, 2018 22:46:19 GMT 1
I used an alloy yz125 off that well known auction site with a bit of modding to the original knuckle. Bit more expensive than the pit bike one but does look good.
Post by stusco on Feb 14, 2018 22:54:58 GMT 1
will27
Post by will27 on Feb 14, 2018 22:58:21 GMT 1
Just bought the last one been looking genuine one for months 👍
Post by rigga on Feb 15, 2018 0:01:31 GMT 1
Converted rd500 tzr 3ma Legend
Post by jessy03 on Feb 17, 2018 16:02:25 GMT 1
I bought one, I couldn’t get it to fit it’s just too small however you can fit it to your existing kickstart knuckle with ease. Can email some pics if needed. Jess
Post by rigga on Feb 17, 2018 20:56:26 GMT 1
Post them on here Jess, all good for the database
murp
Post by murp on Feb 21, 2018 12:09:00 GMT 1
Mine arrived today. ... don't fit... if you expand the knuckle to fit over the spline the bolt won't fit With regard to using existing knuckle the ball bearing is in the opposite bit ..I'll try but don't expect it to work
Post by JonW on Feb 21, 2018 12:21:00 GMT 1
I pulled out my modded YZ125 today. I didnt do it, a mate in the USA did it, and it looks like more work than I thought it might be. While I had it apart Ive cleaned the parts up for zinc'ing and will tidy up the alloy lever.
On someones advice I bought a PW50/80 arm a while back, knock off i think. small and cute but the splined part was no use, about 12mm lol.
Post by dave1963 on Feb 21, 2018 12:47:58 GMT 1
If you open up the hole for the top of the bolt it fits i have 2 one on lc one on ypvs no problems
murp
Post by murp on Feb 21, 2018 15:30:24 GMT 1
Dave ... do you mean drill the hole larger that the bolt goes through so the bolt has more lateral movement to enable it to engage in the threaded bit..
That makes sense. . I'll try it
Post by dave1963 on Feb 21, 2018 17:22:09 GMT 1
Yes mate i do
Post by jessy03 on Feb 21, 2018 17:44:37 GMT 1
Post by loctite on Feb 21, 2018 19:48:00 GMT 1
If stainless steel drill out bolt hole to 9.5mm and use plenty of Kool cutting fluid
Post by 1966baz on Feb 21, 2018 20:13:24 GMT 1
As a simple and relatively cheap option I like the 3xv kickstart. Looks neat on a YPVS hybrid.
Post by Yogi on Feb 21, 2018 20:44:40 GMT 1
Dave ... do you mean drill the hole larger that the bolt goes through so the bolt has more lateral movement to enable it to engage in the threaded bit.. That makes sense. . I'll try it I haven't drilled any of mine,just make sure the bolt ends up in the slot on the spline
murp
Post by murp on Feb 23, 2018 11:42:46 GMT 1
OK. . Fitted this kickstart but it hits the brake pedal... now I know why original has a curved shaft...it looks good but can't use it because of this
Post by urbantangleweed on Mar 15, 2018 23:13:40 GMT 1
Post by Gunny on Mar 17, 2018 20:55:58 GMT 1
Post by wangwang on Mar 17, 2018 21:19:14 GMT 1
Converted rd500 tzr 3ma Legend How did you do the RD500 conversion? I have an RD500 top kicker and an LC knuckle. cheers.
Post by rigga on Mar 18, 2018 8:52:28 GMT 1
No idea unfortunately, I purchased it off a member on here, Nigel Kimber does a version of it I believe.
Post by JonW on Mar 18, 2018 13:13:33 GMT 1
How did you do the RD500 conversion? I have an RD500 top kicker and an LC knuckle. cheers. I thought i showed how i did it on my website? bottom of this page: 2smoked.com/Yamaha_RD350_LC_421cc_Athena_engine.htmlEDITED as this is RD500 kicker related, not the cheapie unit originally discussed.
Post by donkeychomp on Mar 18, 2018 22:22:04 GMT 1
