Post by tony1964 on Feb 5, 2018 10:24:50 GMT 1
Just removed my fuel tap to replace all the seals as my fuel tap is dripping and noticed the mounting bolts have got some sort of sealant on them, should there be a fibre washer or some sort of seal on the mounting bolts??
Tony
Post by Shytalk on Feb 5, 2018 10:29:23 GMT 1
Yes there should be a fibre washer underneath each screw.
Post by tony1964 on Feb 5, 2018 10:42:56 GMT 1
Yes there should be a fibre washer underneath each screw. Thanks Shytalk, Are they the red ones you can get from a plummer's merchant?? Tony
Post by Deleted on Feb 5, 2018 14:17:08 GMT 1
No, you need fuel ones
Plumbers are too thin to create the seal at about 0.2mm
I think they are M6 ID M10 OD by 1mm thick
If the screws are M5 then size is M5 x 9 x 1mm
Hth
Post by Shytalk on Feb 5, 2018 15:38:53 GMT 1
90202-06010 is the Yamaha part number.
Post by lb on Feb 12, 2018 9:53:41 GMT 1
Make sure you using the factory spec screws too,fat head style. Found that most any other type of bolt will leak.
