Post by philmill on Feb 3, 2018 12:47:32 GMT 1
Hi, I have looked through the various threads but cant find the answer but found a lot of interesting info on my project, so can somebody confirm which speedo drives to use with RGV VJ23 forks, also which rear spindle for VJ22 arm, I'm guessing the std RGV spindle on the rear? I was going to use a Bandit 400 cush drive with my GSXR400 wheel. I read this was the correct combination?? Many thanks, Phil
Post by mouse on Feb 4, 2018 11:02:47 GMT 1
Cannot help with the speedo drive, but yes, RGV spindle for RGV arm. You can still buy them new from 'Robinsons Foundry' or the 'Tuning works' or second hand on fleabay
Mouse
Post by philmill on Feb 4, 2018 15:55:01 GMT 1
Thanks Mouse, I didnt realise they were still available, thats a bit of good news.
So anybody else able to help with which speedo drive to use?
Phil
Post by midlifecrisisrd on Feb 4, 2018 19:35:14 GMT 1
Gsxr 400 gk76 rear spindle and adjusters are the same
Post by midlifecrisisrd on Feb 4, 2018 19:36:54 GMT 1
As for the speedo drive what front wheel are you using
That will determine the drive
Vj22 drive still available
Post by philmill on Feb 4, 2018 20:34:33 GMT 1
Thanks Steve, front wheel will probably be either Bandit or GSXR, they seem to be more sensible prices. So do I assume I use the relevant speedo drive? I believe those wheel are the same as RGV anyway? AJ? code.
Phil
Post by midlifecrisisrd on Feb 4, 2018 20:53:19 GMT 1
Mk1 bandit is different as uses a smaller spindle
I had to p1ss about with bearings and spacers to get it to work
I use the rgv drive but had to mod the wheel
If you can I'd use a gsxr gk76 wheel and drive
To complicate things the bandit and RGV have the same code on them hence my problems
Post by wangwang on Feb 4, 2018 21:06:58 GMT 1
Mk1 bandit is different as uses a smaller spindle I had to p1ss about with bearings and spacers to get it to work I use the rgv drive but had to mod the wheel If you can I'd use a gsxr gk76 wheel and drive To complicate things the bandit and RGV have the same code on them hence my problems Steve Think we've had this one before, I used a GK76 front wheel with bandit spindle, spacer and speedo drive, which fit straight in with RGV forks. I also got a GK76 rear spindle which was too narrow for the RGV arm. wang
Post by wangwang on Feb 4, 2018 21:10:53 GMT 1
Post by philmill on Feb 4, 2018 21:39:31 GMT 1
Thanks. I guess I'd better buy GK76 OR VJ22 front wheel then.
Post by philmill on Feb 4, 2018 21:50:54 GMT 1
Thanks Wang, I see the part number for the RGV unit is the same as the GSF600 (Bandit) and early RF600S. I ended up buying the RGV wheel on eBay.
