Post by philmill on Jan 29, 2018 14:05:00 GMT 1
So more questions i'm afraid , is there some kind of fixing on the frame for the airbag? looking at mine when I dismantled it looks as if there should be something on the front edge for the airbag to locate on. If its just a round peg I can get that welded on easy enough. Mind you, the airbag seemed quite rigid as it was just bolted on the back of battery box. Thanks. Phil cYuJ4yDWQzunrqKhEJJY8Q by Philip Millard, on Flickr
Post by mouse on Jan 29, 2018 14:28:02 GMT 1
Hi Phil, yes i'm afraid you are missing the mounting points. I will try and get some pics at the weekend
Mouse
Post by philmill on Jan 29, 2018 15:36:34 GMT 1
Thanks Mouse.
Post by budgie on Jan 29, 2018 20:50:16 GMT 1
Hi Phil Best pics I’ve got from my rebuild a while back, if you zoom in you can see what you’re missing....should be easy for a fabricator to make something.... hope this helps... Gav
Post by philmill on Jan 29, 2018 21:09:59 GMT 1
Thanks Gav, yes that going to be easier than I thought, just a case of getting right position, may have to put cases and barrels in and carbs to get right place.
Post by budgie on Jan 29, 2018 21:20:18 GMT 1
Sounds like a dry build required..!
Post by 350ypvs on Jan 29, 2018 22:29:32 GMT 1
Thanks Gav, yes that going to be easier than I thought, just a case of getting right position, may have to put cases and barrels in and carbs to get right place. Dunno if this helps positioning wise! Was trying to measure from something to give a datum point, if you need measurements let me know where from, frame is pretty bare on mine for next couple of weeks!
Post by philmill on Jan 30, 2018 7:04:45 GMT 1
Thanks, yes as its not s rigid fixing that should be perfect.
Phil
Post by 1966baz on Jan 30, 2018 8:29:57 GMT 1
Had this problem on my latest build and just carefully measured my other F2 for position and welded on 2 rods. Wasn't too bad in the end.
Post by philmill on Jan 30, 2018 10:51:03 GMT 1
Is that a rubber over the peg??
Post by LC_BOTT on Jan 30, 2018 12:00:40 GMT 1
Is that a rubber over the peg?? Yes just a flat cylinder type if that makes sense, (like a cut inner tube) makes the mounting point the same diameter so the airbx just slides onto it.
Post by philmill on Jan 30, 2018 12:16:55 GMT 1
Thanks for that, should be an easy fix then.....
