Post by stusco on Jan 26, 2018 16:12:47 GMT 1
Anyone fitted on to a lc ? I just got mine in the post ,I’m not really impressed it comes with a fitting kit that involves filing the shit out of the tank to make it fit!
Post by Tobyjugs on Jan 26, 2018 16:20:45 GMT 1
I've got one, but i never fitted it. I can only say its got a lovely action,
Post by earthman on Jan 26, 2018 16:30:38 GMT 1
Anyone fitted on to a lc ? I just got mine in the post ,I’m not really impressed it comes with a fitting kit that involves filing the shit out of the tank to make it fit! Oh, that's not good to hear,....I doubt that I'll go down that route then, what you going to do, send it back??
Post by stusco on Jan 26, 2018 16:36:12 GMT 1
Post by Tobyjugs on Jan 26, 2018 16:40:54 GMT 1
I did buy another Pingel but its hi flow,with on and off. The tank still has to be made
Post by Norbo on Jan 26, 2018 16:56:08 GMT 1
You just got the wrong tap i just took one of a bike and it fitted fine on the tank . However i will look a bit closer to see if the attached pice you show is seporate on my one and may be just held on with something but it seems an all 1 pice unit just like an lc one
Post by lrcarl on Jan 26, 2018 17:03:01 GMT 1
Got one for the mito had to file hole in tank larger,cut corners off bracket and shorten lever on fuel tap to make fit
Carl
Post by stusco on Jan 26, 2018 17:06:19 GMT 1
You just got the wrong tap i just took one of a bike and it fitted fine on the tank . However i will look a bit closer to see if the attached pice you show is seporate on my one and may be just held on with something but it seems an all 1 pice unit just like an lc one I bought it from eBay it is listed as for a lc and comes with a fitting kit for 34mm centres same as lc 292404076761 This is the item number for eBay
