Post by philmill on Jan 12, 2018 13:02:52 GMT 1
Hi guys, so I've been playing this morning with my new toy, she runs and sounds great so hopefully engine work will be kept to a minimum, or at least until I start playing at a later date. I will be stripping the motor and having it vapour blasted and painted to look pretty though. But for now have larger issues, the bike has a seat/tail unit fitted and to do this the end of the subframe has been cut off, I have posted on the wanted section hoping somebody has the missing bit but my question is how difficult would refitting this be? I assume there is no major alignment issues and as long as its true to the eye it would be enough?? Or am I being too hopeful. Hopefully pics are attached. IMG_1404 by Philip Millard, on Flickr IMG_1403 by Philip Millard, on Flickr I assume these brackets are not original? IMG_1405 by Philip Millard, on Flickr
Post by steeley on Jan 12, 2018 15:22:36 GMT 1
Hi its a pity you don't have the hacked off bit it would be easy enough to re weld back on . My self I would put a steel slug or tube inside the frame tubes each side and slide the missing end on . Then make sure the panels fitted and weld it up . From the look of it is it a 31k LC2.
Post by budgie on Jan 12, 2018 15:28:17 GMT 1
Hi I just may have those bits as I cut the back end off a 31k frame recently, to convert by race bike frame...so if they are still in the scrap bin at work your welcome to them... I am back in on Monday, just let me know if that’s of interest....
Gavin
Post by philmill on Jan 12, 2018 16:37:56 GMT 1
Hi Gavin, That would be fantastic, I'll keep my fingers crossed. Cheers.
Post by philmill on Jan 12, 2018 17:54:12 GMT 1
I have just seen a picture of a LC2 frame and it seems there is quite a lot missing from the frame, I guess its the bits that fit the side panels etc so I may have a few problems with this, anybody able to send me a decent close up of the section so I can see whats missing. Thanks.
Post by philmill on Jan 12, 2018 19:12:48 GMT 1
Post by steeley on Jan 12, 2018 21:44:59 GMT 1
Post by budgie on Jan 12, 2018 23:40:10 GMT 1
Here is a photo of the back end of my other 31k , hope it helps establish what’s missing, and I will check on Monday what parts I have left...if any...
Post by philmill on Jan 13, 2018 10:48:57 GMT 1
Thanks Budgie, the problem is that all the seat fixings and panel fixing are gone too! I think I bought a dud...... frames seem to be stupidly expensive and repairing this unless I can get the whole frame is probably beyond my capabilities. I'll wait and see what bits you have. Thanks.
Post by jon on Jan 13, 2018 11:36:39 GMT 1
As you say Phil, frames are becoming rarer and rarer to get good ones with V5.
All the more reason to reapair yours. Frames get cut up all the time. In fact kosaprasa has cut several frames up for people wanting brackets.
It may be beyond you to repair, but to a competent welder it’s a doddle.
Post by budgie on Jan 13, 2018 13:17:47 GMT 1
Hoping you can see from this to see what bits you’re missing, but maybe best to get a complete rear end from some frame, and as Jon said, not a difficult job for a decent welder, better to save the frame if you can, especially if it’s a matching numbers bike... I will have a look on Monday for you... Gavin
Post by steeley on Jan 13, 2018 13:37:15 GMT 1
Hi ,don't give up on the frame you have the bits you need are out there in some ones shed/garage. Plenty of folks on here who can use a mig or tig .If your stuck for a seat for it give me a shout .
Post by budgie on Jan 15, 2018 20:49:06 GMT 1
Ok, I’ve raided my scrap bin at work, and here is the fruitful rewards...what’s your thoughts on this lot...enough to restore it? Just let me know if you want this lot and I will get them boxed up for you... Gav
Post by dusty350 on Jan 15, 2018 21:00:08 GMT 1
Result - good work Looks like you'll be back on track Dusty
Post by philmill on Jan 15, 2018 21:33:18 GMT 1
Gav, ghansk, Ive sent a PM
Post by budgie on Jan 15, 2018 21:57:02 GMT 1
Hi Phil
I will get them boxed and away tomorrow... I want nothing from you, I’ve only pulled them out the scrap bin.... so many good people have helped me on here that it would seem wrong to charge you...nice to give something back....hope you find a good guy who can reconstruct the back end for you, hopefully there will be enough parts for you... Just keep us all updated on the progress.!
Gav
Post by LC_BOTT on Jan 15, 2018 22:21:14 GMT 1
Well done budgie nice work
Post by steeley on Jan 16, 2018 11:25:05 GMT 1
Nice job . There you go Phil you are on your way . There are some sound folks on this forum .
Post by budgie on Jan 16, 2018 13:38:59 GMT 1
Hi Phil
All packaged and sent 1st class post today.... so keep an eye out for postie... !
Gav
