Post by dllc on Jan 3, 2018 18:58:53 GMT 1
hi guys. anyone on here use the mitaka 400cc big bore kit for a 350LC? or is a std reline the best way to go to reclaim a set of barrels?
ta
daire
Post by muttsnuts on Jan 3, 2018 21:01:35 GMT 1
you got a link to them, not sure I've ever seen any
Post by lrcarl on Jan 3, 2018 21:38:07 GMT 1
ORE KIT (400cc) ALL PARTS FOR RD500 ALSO AVALABLE LINER 75.00 PISTON KIT (68mm) 42.75 RD250/350LC NEW CRANKSHAFT 342.47
2 LINERS FITTED & PISTON KITS SUPPLIED 265.50
Post by lrcarl on Jan 3, 2018 21:41:11 GMT 1
That didn’t go well Mitaka web site 2 68mm pistons and liners £265 Carl
Post by muttsnuts on Jan 3, 2018 21:53:36 GMT 1
ah ok, that is the Grampian site, they don't do them anymore, or at least when I asked last year they said they didn't, makes the bike 392cc, funnily enough I am having a set of barrels done to that spec shortly to go in my new prototype LC engine, if it works I'll be posting up on here the results, if it doesn't, I'll be keeping my mouth shut !!
Post by Mr Kipling on Jan 3, 2018 22:04:09 GMT 1
if it works I'll be posting up on here the results, if it doesn't, I'll be keeping my mouth shut !! made me chuckle ... :D
Post by Tobyjugs on Jan 3, 2018 22:06:16 GMT 1
ah ok, that is the Grampian site, they don't do them anymore, or at least when I asked last year they said they didn't, makes the bike 392cc, funnily enough I am having a set of barrels done to that spec shortly to go in my new prototype LC engine, if it works I'll be posting up on here the results, if it doesn't, I'll be keeping my mouth shut !! Norbos got a set in his closet was tempted to buy them but changed me mind. He has the same type which is fitted to my hybrid YPVS engine
Post by JonW on Jan 4, 2018 0:11:46 GMT 1
Be really careful with Mitaka, the Japanese made stuff Ive had from them has been ok, but the set of pistons Ive had recently from Taiwan were shocking.
Post by bare on Jan 4, 2018 2:30:04 GMT 1
What!.. worried the piston tops might come off ? Naww.. there's no history of that.. is there? IMO..Bin the liner notion, suggest instead having the bores Nicasil'd. Pricey certainly.. but a whole World more able solution than stuffing a piece of pipe into your barrels.
Post by beardy on Jan 4, 2018 10:04:11 GMT 1
apologies if it seems i`m hijacking the thread. are there any members that have actually had their old worn out barrels re sleeved? was it a success and who did you use to do the work? i`m sure there must be a few of us looking for solutions to this inevitable issue.
Post by muttsnuts on Jan 4, 2018 10:12:47 GMT 1
apologies if it seems i`m hijacking the thread. are there any members that have actually had their old worn out barrels re sleeved? was it a success and who did you use to do the work? i`m sure there must be a few of us looking for solutions to this inevitable issue. yes, had a good number of barrels relined for customers and also my own personal use, not had any issues or failures. I've used PJME for this service and been very happy with the service and work done
Post by wallcraft on Jan 4, 2018 18:52:35 GMT 1
Yep had mine re-lined by local tuner Harry Barlow, put 3k miles on now with no issues.
Mark
Post by dllc on Jan 4, 2018 19:25:35 GMT 1
thanks guys. rang grampion and they have no stock left. so looks like a reline.
does anyone have a number for harry barlow?
or muttnuts what is your timeframe with your experiment. do you want a guinea pig?
rgds
daire
Post by Tobyjugs on Jan 4, 2018 19:31:46 GMT 1
thanks guys. rang grampion and they have no stock left. so looks like a reline. does anyone have a number for harry barlow? or muttnuts what is your timeframe with your experiment. do you want a guinea pig? rgds daire Norbo has what you want. Give him a ring
Post by markhoopy on Jan 4, 2018 23:58:12 GMT 1
funnily enough I am having a set of barrels done to that spec shortly to go in my new prototype LC engine, if it works I'll be posting up on here the results, if it doesn't, I'll be keeping my mouth shut !! You need a master plan Dave to stop you jumping from prototype to prototype .. start by finishing your turbo!
Post by muttsnuts on Jan 5, 2018 11:26:17 GMT 1
Mark, funny you should say that, I am doing exactly that, I am working through all of my backed up projects, this one is the oldest, the 1st generation engine is going into the test bike today, might even get it run up !, if that works like I think, then a few mods and then these barrels to take it as far as I can. Then while I am waiting on the barrels I've got 2 of my road bikes to sort, and then, wait for it, the turbo is going back on the bench for finishing, I am determined to finish it this year one way or the other I'll keep you posted !
Post by Tobyjugs on Jan 5, 2018 12:00:59 GMT 1
Id love to see the turbo bike, it must be a bit complex with an extra oil tank and pump etc
Post by rigga on Jan 5, 2018 12:03:15 GMT 1
Certainly interested in this Dave, the LC lump still has followers who would like a little more oomph, instead of fitting a ypvs motor.
Post by Tobyjugs on Jan 5, 2018 12:05:38 GMT 1
Me as well i like the LC motor best
Post by muttsnuts on Jan 5, 2018 13:39:47 GMT 1
well we should know later today as the engine is in, just sorting some carbs out for it, exhausts are sorted, as are the electronics, so bar some wiring, rad etc to fit, she should be firing up in around 3hrs time I'd say
Post by rigga on Jan 5, 2018 15:07:24 GMT 1
Well stop popping on here and get it done
Mad Biker
We lead others try and follow.
Post by Mad Biker on Jan 5, 2018 17:52:00 GMT 1
We've had a couple of 400cc Lc's done using long stroke cranks but it works out more expensive that way
Post by Mr Kipling on Jan 5, 2018 19:16:17 GMT 1
Seen the turbo,s on the banshee motors be interesting too see one on a LC... Banshee Turbo
Post by muttsnuts on Jan 5, 2018 21:22:22 GMT 1
We've had a couple of 400cc Lc's done using long stroke cranks but it works out more expensive that way I am using a 4mm stroked LC crank, not a YPVS crank, its looking promising, not sure the exhausts are right for it, but got it upto 56bhp and 35ftlbs of torque so far and that's on standard porting, my current gambit is to try and keep the motor as stock as possible and just replace the crank to give more mid range and grunt, which is exactly what it has done, its giving out better power than fitting a set of the mid range pipes to a stock LC and of course more power. I've still got a lot of work to do, but I am going to fit a set of mid range pipes on it shortly to see what it does, should be interesting as I reckon it will have a mega mid range ! I'll sort out a write up of it all shortly for those interested You know me Martin, I am all about mid range and driveability, not big numbers or blowing motors !!
Post by muttsnuts on Jan 5, 2018 21:23:26 GMT 1
Seen the turbo,s on the banshee motors be interesting too see one on a LC... Banshee Turbo yep, one thing building it ona stand, a whole different ball game getting it to actually work, plus mine is a twin turbo !! I will be getting back onto it this year, so watch this space
Post by Tobyjugs on Jan 5, 2018 21:49:34 GMT 1
We've had a couple of 400cc Lc's done using long stroke cranks but it works out more expensive that way I am using a 4mm stroked LC crank, not a YPVS crank, its looking promising, not sure the exhausts are right for it, but got it upto 56bhp and 35ftlbs of torque so far and that's on standard porting, my current gambit is to try and keep the motor as stock as possible and just replace the crank to give more mid range and grunt, which is exactly what it has done, its giving out better power than fitting a set of the mid range pipes to a stock LC and of course more power. I've still got a lot of work to do, but I am going to fit a set of mid range pipes on it shortly to see what it does, should be interesting as I reckon it will have a mega mid range ! I'll sort out a write up of it all shortly for those interested You know me Martin, I am all about mid range and driveability, not big numbers or blowing motors !! 373 cc's with standard bore or are you going 68mm?
Post by Tobyjugs on Jan 5, 2018 21:55:40 GMT 1
Another question for mutts, when are you going to have a dyno day??
Post by marsbar350 on Jan 5, 2018 22:55:43 GMT 1
Another question for mutts, when are you going to have a dyno day?? hey toby daves waiting for the southern hybrid club to find a date in there diary
Post by muttsnuts on Jan 5, 2018 23:15:23 GMT 1
Another question for mutts, when are you going to have a dyno day?? hey toby daves waiting for the southern hybrid club to find a date in there diary it will be a long wait then !!!........
Post by muttsnuts on Jan 5, 2018 23:15:54 GMT 1
Another question for mutts, when are you going to have a dyno day?? will see if I can organise something, subject to enough interest of course
