Post by bezzer on Dec 13, 2017 19:30:06 GMT 1
Evening gents,
Anyone have any input on fitting a rear disc to the standard ’italic’ spoked 250/350 rear wheel?, also the best calliper to use?.
Thanks in advance, bezzer
Post by 0h5h1t on Dec 13, 2017 20:09:02 GMT 1
Post by oldelsieboy on Dec 13, 2017 20:11:29 GMT 1
Post by 0h5h1t on Dec 13, 2017 20:31:46 GMT 1
Post by bezzer on Dec 13, 2017 21:02:12 GMT 1
Thanks for the link mate, looks cool - shame it wasn’t the view of the disc side though!.
Post by oldelsieboy on Dec 13, 2017 21:11:42 GMT 1
Thanks for the link mate, looks cool - shame it wasn’t the view of the disc side though!. OEB
Post by bezzer on Dec 13, 2017 21:17:03 GMT 1
Thanks for the link mate, looks cool - shame it wasn’t the view of the disc side though!. OEB Thanks Nigel, Disc looks standard LC front.
Post by iwantalc on Dec 13, 2017 21:46:25 GMT 1
disc is standard front so is the wheel he converts a front wheel to accept a sprocket..
Post by bezzer on Dec 13, 2017 21:51:45 GMT 1
disc is standard front so is the wheel he converts a front wheel to accept a sprocket.. Ahh, I see, so does he mod the bearing housings to accept the larger bearing/rear spindle as well?.
Post by wallcraft on Dec 13, 2017 22:19:50 GMT 1
Just shy of 500 notes all in if NK does it!!
Post by barney on Dec 13, 2017 22:54:08 GMT 1
disc is standard front so is the wheel he converts a front wheel to accept a sprocket.. Ahh, I see, so does he mod the bearing housings to accept the larger bearing/rear spindle as well?. Mod comes with everything you need just so slide in the rear spindle, new sprocket carrier,sprocket ,spacers and rear brake hanger 👍
Post by rich on Dec 14, 2017 0:12:18 GMT 1
Post by bezzer on Dec 14, 2017 8:00:26 GMT 1
Ahh, I see, so does he mod the bearing housings to accept the larger bearing/rear spindle as well?. Mod comes with everything you need just so slide in the rear spindle, new sprocket carrier,sprocket ,spacers and rear brake hanger 👍 Cheers for the info Barney 👍🏻
Post by earthman on Dec 14, 2017 8:42:28 GMT 1
From what I remember, the standard drum brake were more than adequate, are you guys really noticing a difference or is it for cosmetic reasons mainly?
Post by bare on Dec 14, 2017 19:10:01 GMT 1
Bling .. basically imo. Old unsophisticated rear drum works V well and is more easily feathered in use.. which is actually rare. In street uses rear brake is mostly for hill holding
Post by robin on Dec 14, 2017 21:11:48 GMT 1
This one is mine NK conversion
Post by bezzer on Dec 14, 2017 21:19:05 GMT 1
This one is mine NK conversion Great looking bike Robin - thanks for posting 👍🏻
Post by robin on Dec 14, 2017 21:22:22 GMT 1
This one is mine NK conversion Standard rear wheel spindle, bearings are modified to take the larger diameter, custom marchanesi cush drive and sprocket, I used a 31K rear caliper and bracket, I had it mounted upside, rather than slung below, personal choice. Its harsh, but you get used to it, it certainly works well.
Post by robin on Dec 14, 2017 21:24:22 GMT 1
send me a PM with your email and I will send some build pictures if you want them
Post by bezzer on Dec 14, 2017 22:07:46 GMT 1
send me a PM with your email and I will send some build pictures if you want them Done mate.
Post by barney on Dec 14, 2017 22:15:18 GMT 1
Nothing wrong with a bit of bling
