Carbs
Dec 12, 2017 22:04:51 GMT 1
via mobile
Post by greeny on Dec 12, 2017 22:04:51 GMT 1
Hi all. What is the standard carb set up on 350lc. Just picked one up and its had a carb overhaul but not set up correct. Are there i.d No's on jets needles etc. Basically Whats size jet,needles, and chips on needles etc. Many thanks Ian
Carbs
Dec 12, 2017 22:10:23 GMT 1
Post by rigga on Dec 12, 2017 22:10:23 GMT 1
Carbs
Dec 12, 2017 23:55:20 GMT 1
via mobile
Post by paulperth on Dec 12, 2017 23:55:20 GMT 1
Mutts the forum guru sent me this a year ago hope it helps
New/Replacement Parts Needle Jets - 345-P2 Pilot Jets - 22.5 Main Jets - 220
Needle clip position - 3 Air Screw - 1.5 turns out
In addition float height has been set to 21mm +/- 0.5mm
Good luck
Paul
