Post by wangwang on Nov 25, 2017 15:10:19 GMT 1
What sort of alternatives to the standard LC temp gauge are available?. I'm not using LC clocks on my build, I've got some off an XS something or other, when I work out how to get the trip knob off I can put a new face/innards in the speedo, but will have no temp gauge in the rev counter. Cheers wang
Post by LC_BOTT on Nov 25, 2017 15:23:20 GMT 1
Don't you want to use a digital one? I was wondering if it's possible to fit a fuel gauge, just depends what resistance range is required for full movement. Or if you don't mind another add on, could you use an F2 type gauge.
Post by wangwang on Nov 25, 2017 16:01:01 GMT 1
Don't you want to use a digital one? I was wondering if it's possible to fit a fuel gauge, just depends what resistance range is required for full movement. Or if you don't mind another add on, could you use an F2 type gauge. I think the F2 one is a bit large, but a small digital one might work.
Post by stusco on Nov 25, 2017 16:12:04 GMT 1
The trip knob will be a left hand thread
Post by wangwang on Nov 25, 2017 16:25:11 GMT 1
The trip knob will be a left hand thread It's a right git to get off, LC and YPVS ones, no bother, this one!!!!
Post by oldelsieboy on Nov 25, 2017 16:28:25 GMT 1
Post by rigga on Nov 25, 2017 17:01:18 GMT 1
If you don't mind looking down at the engine Norbo sells an inline gauge that fits between the water pump and radiator, simple but effective.
