corsur
Post by corsur on Nov 24, 2017 19:01:55 GMT 1
Hi guys can someone recommend a good battery for the RD 350 YPVS R When I was restoring the bike a just bought a cheap ebay one to get it going. But as they say you only get what you pay for. So now looking the best I can get Any recommendation please.
Post by cb250g5 on Nov 24, 2017 19:15:36 GMT 1
I like Motobatt. Bearing in mind you don't actually need it for anything, a cheapo lead acid one should be fine.
Post by dusty350 on Nov 24, 2017 19:44:00 GMT 1
+1 for Motobatt. AGM technology means no acid spills Dusty
Post by bare on Nov 24, 2017 19:44:43 GMT 1
Whats' wrong with your Cheapo battery.. has it Died ? Some Chargers have a Desulphate setting which sometimes revives the things. Lead acid batteries typically get killed by Primitive charge systems (not much to be done there :-) .. even 'good batteries', although those do soldier on a bit longer. Sometimes multiple cheap batteries are more cost effective than a couple of Pricey ones
Post by dusty350 on Nov 24, 2017 20:01:03 GMT 1
Pretty sure Norbo does the Motobatt for £25.00. Bargain Dusty
Post by aid22 on Nov 24, 2017 20:36:12 GMT 1
I second Bare. Never gone wrong with Yuasa Batteries myself(lead acid and not cheap) on my bikes in the past. It depends on what you want from and expect from your battery.
Aid.
corsur
Post by corsur on Nov 25, 2017 0:04:26 GMT 1
Whats' wrong with your Cheapo battery.. has it Died ? Some Chargers have a Desulphate setting which sometimes revives the things. Lead acid batteries typically get killed by Primitive charge systems (not much to be done there :-) .. even 'good batteries', although those do soldier on a bit longer. Sometimes multiple cheap batteries are more cost effective than a couple of Pricey ones Yes its not holding the charge Needs charging ever week. And I use a good Ctek charger.
Post by wallcraft on Nov 25, 2017 9:04:44 GMT 1
If you want originality then it's the lead acid and when looked after ie optimate hooked up they last well, had mine now for 7 years. I'm sure it's a Yuasa, shows how many times I look at it!!
Post by dusty350 on Nov 25, 2017 9:24:36 GMT 1
Yuasa's are great batteries - I always used them back in the day. I also used to get acid spills from the vent pipe on my chrome pipes , hence I prefer the AGM batteries nowadays, but I'm sure if you fit a lead acid Yuasa it will work fine. Dusty
Post by mannanan on Nov 25, 2017 10:16:35 GMT 1
Always been happy with the Yuasa YBL-5 in my F2. However, next time I shall probably try the Motobatt. Checking the spec it seems I need the MB5.5U but that’s 15mm longer than the Yuasa. Will that still fit comfortably in the battery carrier? ( The MB5 looks the same size as the Yuasa.) So which one for an F2 model?
Post by cb250g5 on Nov 25, 2017 11:39:41 GMT 1
Does it matter that it's not holding charge? My hybrid battery was like that for years, it's not part of the ignition system, so the bike fires up fine & then everything works OK. It would charge, but lose it within a week or so.
Post by stusco on Nov 25, 2017 11:43:51 GMT 1
Does it matter that it's not holding charge? My hybrid battery was like that for years, it's not part of the ignition system, so the bike fires up fine & then everything works OK. It would charge, but lose it within a week or so. Unless you have a zeel😏
Post by 0h5h1t on Nov 25, 2017 12:01:52 GMT 1
Does it matter that it's not holding charge? My hybrid battery was like that for years, it's not part of the ignition system, so the bike fires up fine & then everything works OK. It would charge, but lose it within a week or so. Unless you have a zeel😏 I think Zeels star ok with a flat battery, mine does anyway but if you have an ignitech then no it wont start with a flat battery i dont think. My mates wont anyway but he does have a power dynamo fitted as well so maybe that has an effect on the upgraded CDI's
coose
Post by coose on Nov 25, 2017 12:15:16 GMT 1
Yuasa every time. I've had a few friends that have had failed Motobatts. It appears that the links between the plates can fracture and then weld themselves back together, giving an intermittent fault. Each time the issue has been fixed with a Yuasa lead acid.
Post by cb250g5 on Nov 25, 2017 16:50:08 GMT 1
Does it matter that it's not holding charge? My hybrid battery was like that for years, it's not part of the ignition system, so the bike fires up fine & then everything works OK. It would charge, but lose it within a week or so. Unless you have a zeel😏 Point taken.
Post by bare on Nov 28, 2017 4:38:46 GMT 1
Small update: Bought a New High Zoot Processor controlled battery charger on Friday (Black Friday sale) for 60$ Has a Desulphate function and the gizmo self detects the need and sets to fixing the problem. Short story; a 4 years on my bench/out of my 350 Battery, a cheap taiwanese one to boot. I set the Nifty charger to it. Damned thing decided the Bat was Sulphated No news there, Visually obvious to me. The thing worked away at the Battery for two whole days, alternating between Desulphate (High Amp; 25 to 50.. Pulses) and regular chargings. This AM the unit readout said the Battery was at 100% capacity.. charging / desulphate cycles had been completed. Damned if all the white frost was gone and a subsequent Load test(by Me) revealed that the thing was "good" I'm Chuffed.
Post by scooter on May 1, 2018 18:31:42 GMT 1
motobatt is fine on mine
Post by 4l04ever on May 2, 2018 7:43:57 GMT 1
Small update: Bought a New High Zoot Processor controlled battery charger on Friday (Black Friday sale) for 60$ Has a Desulphate function and the gizmo self detects the need and sets to fixing the problem. Short story; a 4 years on my bench/out of my 350 Battery, a cheap taiwanese one to boot. I set the Nifty charger to it. Damned thing decided the Bat was Sulphated No news there, Visually obvious to me. The thing worked away at the Battery for two whole days, alternating between Desulphate (High Amp; 25 to 50.. Pulses) and regular chargings. This AM the unit readout said the Battery was at 100% capacity.. charging / desulphate cycles had been completed. Damned if all the white frost was gone and a subsequent Load test(by Me) revealed that the thing was "good" I'm Chuffed. Can you put a link up for the charger you acquired?
