Post by Tobyjugs on Nov 8, 2017 22:16:50 GMT 1
Why is the balance pipe on a 4LO engine smaller than on a YPVS engine?
Does anyone use their engine without a balance pipe?
If you don't use a balance pipe, what is your reason for this?
Post by oldelsieboy on Nov 8, 2017 23:10:17 GMT 1
Why is the balance pipe on a 4LO engine smaller than on a YPVS engine? Maybe the diameter of the balance pipe is proportional to the size of the reed valves. OEB
Post by Tobyjugs on Nov 8, 2017 23:20:01 GMT 1
Yes that sounds logical
Post by 4l04ever on Nov 8, 2017 23:43:34 GMT 1
It would affect how much fuel/air mixture could cross over to the opposite side.
Post by bare on Nov 9, 2017 1:50:37 GMT 1
Does anyone use their engine without a balance pipe? If you don't use a balance pipe, what is your reason for this? Erm .. No .. The thing runs smoother idles better with the pipe in place. Easy enough to experiment and see for yourself.
Post by Tobyjugs on Nov 9, 2017 4:22:20 GMT 1
Does anyone use their engine without a balance pipe? If you don't use a balance pipe, what is your reason for this? Erm .. No .. The thing runs smoother idles better with the pipe in place. Easy enough to experiment and see for yourself. I Have to make some sort of balance pipe bare, and i will test without as well
Post by tsa on Nov 9, 2017 13:41:04 GMT 1
You can also try 2 separate boost bottles.
Post by Tobyjugs on Nov 9, 2017 15:18:22 GMT 1
You can also try 2 separate boost bottles. Oh my goodness don't start that? I have looked into it and it seems to be a lot equations needed. I do agree that it should be separate bottles. I have a modified air manifold but there is no provision for a balance pipe. I still need to do this and i was hoping there was a member with opinions or experience about balance pipe size.
Post by LC_BOTT on Nov 9, 2017 16:11:16 GMT 1
Isn't the manifold drilled internally, I'm sure mine has a small passage between both sides. The RGV's just use two lengths of pipe and cross over between both rubber manifolds, up and down under the tank, quite simple, and easy to hide.
Post by Tobyjugs on Nov 9, 2017 18:33:01 GMT 1
Isn't the manifold drilled internally, I'm sure mine has a small passage between both sides. The RGV's just use two lengths of pipe and cross over between both rubber manifolds, up and down under the tank, quite simple, and easy to hide. Hi BOTT your correct there is an extra plate with two channels milled into it making an internal balance tube. I didn't want to wreck that part of the manifold. The piece you see above can be put back to normal.
