jonno
Post by jonno on Nov 13, 2005 17:14:36 GMT 1
Hi all,
After being messed about by the seller of an RGV250 which i was after to modify my YPVS F2, i came across the following:
An RD 350 LC with a new MOT, Hand painted yellow bodywork fitted with a YPVS Motor, Allspeed's and K&N filters!! Although it looks a mess (Paintwork), it appears straight and tempted me enough to part with the necessary Dosh to make it mine. I have allways preferred the look of the original LC but for obvious reasons, prefer the power of the later YPVS.
Perhaps you guys can give me some ideas on what modifications i could do to the basic LC frame and forks?
Thanks.
Post by wiggy on Nov 13, 2005 17:17:56 GMT 1
ive got an lc/ypvs hybrid not too much modded tho apart from the motor and f2 front end( see pics in another thread)
a lot of people seem to like to put rgv front and rear ends in
jonno
Post by jonno on Nov 13, 2005 17:22:23 GMT 1
Wiggy,
Did you put the F2 front end on?
What wheels are you using?
Post by Norbo on Nov 13, 2005 17:39:35 GMT 1
You can up grade your forks , Disks and caliperes with out much bother
Post by wiggy on Nov 13, 2005 17:46:02 GMT 1
Wiggy, Did you put the F2 front end on? What wheels are you using? COMPLETE FRONT END EXCEPT CLOCKS AND HEADLIGHT IVE GOT ORIGINAL LC WHEELS AND USE THE FORKS (F2) AND CALLIPERS WITH FRONT MUDGUARD
Post by Norbo on Nov 13, 2005 18:00:46 GMT 1
I do think they look nice with YPVS wheels and forks on as well as the YPVS engine. You dont have to do a grate deal to mod the back brake to have a mas cylinder on it for a rear disk.
Post by Norbo on Nov 14, 2005 19:00:51 GMT 1
Anything that looks good if you do it your self is allways a nightmare but the satisfaction of a good final job makes it all worth wile.
