Post by looey on Oct 19, 2017 11:54:36 GMT 1
I need to buy an F2 throttle tube. Norbo doesn't seem to list them at all (unless I couldn't see them for looking) ?. I know Yambits is a swear word on here (mainly for seals I know ) but has anyone tried their pattern F2 throttle tube ?. Cheers
Post by JonW on Oct 19, 2017 12:26:11 GMT 1
I need one too... so interested in this...
Post by looey on Oct 19, 2017 12:37:01 GMT 1
I need one too... so interested in this... Why don't you buy the Yambits one (£6.99 + delivery) and let me know if it's any good ?
Post by JonW on Oct 19, 2017 12:44:54 GMT 1
Its a project for the future, me buying one today wont net you any results until about 2020 lol
Post by Norbo on Oct 19, 2017 15:12:19 GMT 1
ask how long it is first remember they are 10mm longer then an lc one i had one from the wholsaler and it was to short so dont list them
Post by looey on Oct 19, 2017 15:21:22 GMT 1
Good call Norbo, anyone know how long the F2 tube should measure ?, or can measure one for us ?. Is the F2 tube longer than the LC2/31k does nyone know ?. I currently have an 31K/LC2 throttle tube in an F2 switchgear and it's impossible to get the slack out of the cable .
Post by midlifecrisisrd on Oct 19, 2017 16:09:03 GMT 1
I'm sure it's the same length as the lc2 as they use the same grips.
It's the nipple position that's different
Post by midlifecrisisrd on Oct 19, 2017 16:17:02 GMT 1
Post by muttsnuts on Oct 19, 2017 16:52:08 GMT 1
or do what I do and just shorten the cable by removing the throttle tube end nipple and solder a new one one, iirc you need to remove approx 10mm including the size of the nipple, so its baout 5mm of cable +mthe nipple
HTH
Post by stusco on Oct 19, 2017 18:18:13 GMT 1
Cut a groove in the tube for the cable so it reaches the next hole no more slack ps it was a nos f2 tube and I cut it to fit my lc grips
Post by looey on Oct 19, 2017 18:31:25 GMT 1
Cut a groove in the tube for the cable so it reaches the next hole no more slack ps it was a nos f2 tube and I cut it to fit my lc grips That's a good suggestion, I'll have a look see if that's an option on mine. Cheers
Post by dusty350 on Oct 19, 2017 20:35:12 GMT 1
Hi Looey Hope you and Mrs Looey are well Pretty sure this is F2 - it came off an F2 anyway; 20171019_175928 by David Miller, on Flickr The bar end part of the tube is a bit rough but I think this is the original length as far as I can tell. Dusty
Post by looey on Oct 19, 2017 21:24:43 GMT 1
Cheers for that Mr Dusty I'll get mine off in the next few days (doing front calipers at mo) and measure up, see if I can modify it like has been suggested to make it work
Post by JonW on Oct 20, 2017 0:04:40 GMT 1
I guess the LC2 version of the cable would be a touch long due to the higher bars so that wouldnt be a fix. Its pretty sad that in the modern world someone cant run up a bunch of these really, its not a racket science part lol. In the meantime I'll keep looking, I dont have one to modify sadly or Id go that route. I could buy 2 yambits ones and cut and weld on the missing 10cm i guess lol
Post by looey on Oct 20, 2017 9:23:49 GMT 1
The problem I have is that I've got a 31k throttle tube in an F2 housing/switchgear, so god knows what that combination does.
I've got 31k carbs and a Norbo Jap quality throttle cable, so pretty sure the tube is the problem.
I made a couple of spacers either end of the top cable for now and got rid of the excess free play but next week I'll see if I can modify the 31K tube, if not, I'll order an F2 tube from Yambits and see if that sorts it.
I'll let you know Jon
Post by JonW on Oct 20, 2017 9:45:21 GMT 1
Cheers Looey, my breath is baited
