Post by looey on Oct 11, 2017 22:36:58 GMT 1
Anyone replaced the diaphragm in a YPVS Petrol Tap ?. The diaphragm has 2 parts and doesn't look like it comes apart ?. Am I right that one side needs to be pulled through the hole in the centre of the plastic section that sits in-between them ?. Is that right ?, looks like it would damage it getting it through Cheers
Post by midlifecrisisrd on Oct 12, 2017 8:40:28 GMT 1
Done a few now. Yes you need to pull it through the hole
If you gather all corners together and pole them through the hole it goes through no problem with a bit of wiggling
Post by looey on Oct 12, 2017 9:20:01 GMT 1
Thanks mate,
I was pretty sure that was the only option but wanted to be sure before I did it.
Thanks again
Post by looey on Oct 12, 2017 10:49:14 GMT 1
Done and fitted.
Bit fiddly but good results.
All the old rubber parts that came out we’re like concrete covered in syrup lol
