Post by wangwang on Oct 11, 2017 20:52:16 GMT 1
Am using 31k forks and yokes on my project with clip ons. Not really sure what to do about the redundant bar clamps, any ideas? cheers wang
Post by andy748 on Oct 11, 2017 21:07:14 GMT 1
Could you not get them machined off, or use F2 yokes modded for your clocks? Andy.
Post by bare on Oct 11, 2017 22:05:24 GMT 1
You could remove the top part of the handlebar clamps Then fit a thin black strap and smaller screws to finish it off. In the least it would be much less obtrusive and wouldn't involve cutting up the Yoke.
Post by veg on Oct 12, 2017 12:11:42 GMT 1
Buy a spare one and have the clamps machined off will look so much better
Post by marsbar350 on Oct 12, 2017 18:16:42 GMT 1
those yokes are worth money!! sell them onto some one upgrading LC forks to F2
Post by aid22 on Oct 12, 2017 19:22:48 GMT 1
Let me know if you are selling them. Thanks.
Post by JonW on Oct 13, 2017 0:43:41 GMT 1
F1 and F2 yokes are what you need. Sell the ones you have to cover the swap cost.
31k Yokes
Oct 13, 2017 7:04:22 GMT 1
via mobile
Post by wangwang on Oct 13, 2017 7:04:22 GMT 1
F1 and F2 yokes are what you need. Sell the ones you have to cover the swap cost. I already have some F1 F2 yokes, just need to find someone to weld some brackets on!
31k Yokes
Oct 13, 2017 10:08:34 GMT 1
via mobile
Post by midlifecrisisrd on Oct 13, 2017 10:08:34 GMT 1
F1 and F2 yokes are what you need. Sell the ones you have to cover the swap cost. I already have some F1 F2 yokes, just need to find someone to weld some brackets on! NK racing will do it Steve
Post by JonW on Oct 13, 2017 13:17:17 GMT 1
Confused... you wanted to know what to do, and the quick answer was to fit the top triple/yoke from an F1/N1/F2/N2... which if you have it is simple as the lower is the same LC2/31k so just swap the top. If you used those top yokes you can use their bars and not need brackets welding...
31k Yokes
Oct 13, 2017 20:36:00 GMT 1
via mobile
Post by midlifecrisisrd on Oct 13, 2017 20:36:00 GMT 1
Confused... you wanted to know what to do, and the quick answer was to fit the top triple/yoke from an F1/N1/F2/N2... which if you have it is simple as the lower is the same LC2/31k so just swap the top. If you used those top yokes you can use their bars and not need brackets welding... But you can't mount LC clocks to f/n yokes without welding on lugs or making a bracket Steve
Post by JonW on Oct 13, 2017 23:40:31 GMT 1
Very true Steve, I see what you mean.
31k Yokes
Oct 15, 2017 11:55:58 GMT 1
via mobile
Post by kman on Oct 15, 2017 11:55:58 GMT 1
Wangwang. Which country are you in.
31k Yokes
Oct 15, 2017 20:57:05 GMT 1
via mobile
Post by wangwang on Oct 15, 2017 20:57:05 GMT 1
Wangwang. Which country are you in. UK
31k Yokes
Oct 17, 2017 10:16:17 GMT 1
via mobile
Post by kman on Oct 17, 2017 10:16:17 GMT 1
Pitty. I have one i could send u if u were in oz. I had the mounts ground of.holes rewelded and finished. Worked a treat. Easy job.looks factory.
Post by aid22 on Oct 17, 2017 11:20:39 GMT 1
Hi kman, can you post a picture of that please. Thanks.
31k Yokes
Oct 17, 2017 12:08:46 GMT 1
via mobile
Post by kman on Oct 17, 2017 12:08:46 GMT 1
Can try.
31k Yokes
Oct 17, 2017 12:29:44 GMT 1
via mobile
Post by wangwang on Oct 17, 2017 12:29:44 GMT 1
Pitty. I have one i could send u if u were in oz. I had the mounts ground of.holes rewelded and finished. Worked a treat. Easy job.looks factory. Depends which bit of Oz, my son is over there next month ;-)
Post by wangwang on Nov 27, 2017 21:03:01 GMT 1
Post by jon on Nov 28, 2017 19:37:35 GMT 1
Just a question, as they do look much better, but why did you not get the original clip on positioning threads welded up at the same time?
Maybe it's having beetles in the past, but we were always trying to get that 'cal look' by smoothing and filling everything possible.
Did a second take, and I noticed you changed from LC clocks to air cooled?
Post by dusty350 on Nov 28, 2017 21:05:57 GMT 1
The yokes look great - bit more like Tz yokes Dusty
31k Yokes
Nov 29, 2017 19:54:47 GMT 1
via mobile
Post by wangwang on Nov 29, 2017 19:54:47 GMT 1
Just a question, as they do look much better, but why did you not get the original clip on positioning threads welded up at the same time? Maybe it's having beetles in the past, but we were always trying to get that 'cal look' by smoothing and filling everything possible. Did a second take, and I noticed you changed from LC clocks to air cooled? Jon Left the holes for the standard bars just in case I can't get on with the clip ons being so low. The XS clocks look better than the LC ones, just need to sort a temp gauge out and change the innards on the Speedo.
Post by jon on Nov 29, 2017 20:05:39 GMT 1
Just a question, as they do look much better, but why did you not get the original clip on positioning threads welded up at the same time? Maybe it's having beetles in the past, but we were always trying to get that 'cal look' by smoothing and filling everything possible. Did a second take, and I noticed you changed from LC clocks to air cooled? Jon Left the holes for the standard bars just in case I can't get on with the clip ons being so low. The XS clocks look better than the LC ones, just need to sort a temp gauge out and change the innards on the Speedo. Oh the're XS clocks, I see. Good idea about the clipons as I would struggle with those too. Only problem you might face is that the front end may be too low with the 31k forks and F2 clipons. Jon
Post by bare on Nov 30, 2017 0:12:05 GMT 1
Too low would only be the Ergonomics problem . Dropping the 31k forks to fit the oem Yama 'clip ons' would mess the Steering geometry. Nothing is ever as simple as it seems.
Post by JonW on Dec 8, 2017 3:07:34 GMT 1
Yeah youre back to needing more parts if you want the clip ons on top of the bars like OEM as the 85-on legs are longer. Looks good with the XS clocks tho, something new
31k Yokes
Dec 8, 2017 23:13:53 GMT 1
via mobile
Post by wangwang on Dec 8, 2017 23:13:53 GMT 1
Yeah youre back to needing more parts if you want the clip ons on top of the bars like OEM as the 85-on legs are longer. Looks good with the XS clocks tho, something new I have some F2 forks to strip just in case ;-)
