Post by victor on Oct 2, 2017 21:35:07 GMT 1
Hi
Still having problems with carbs weeping fuel from float bowl gasket. I know what the float height should be set at but where should the fuel level be relative to the gasket? I have fitted transparent side tubes and the level with the floats set at 21mm seems very close to the gasket level ..... where do people think it should be?
Thanks Greg
Post by looey on Oct 2, 2017 21:50:38 GMT 1
Shouldn't leak from the float bowl gaskets whatever the level of the fuel in the carbs.
If the level gets too high, it should overflow into the brass tubes and out of the back/bottom of the float bowls
Even then, it should leak from the gaskets.
Have you fitted new gaskets ?.
Post by victor on Oct 2, 2017 22:49:44 GMT 1
Yes new gaskets and new float valves. No sign of any damage to faces. Does not overflow just gradually seeps. Same on both carbs.
Post by victor on Oct 7, 2017 15:56:14 GMT 1
Hi
I asked before but did not get an answer so will try again as this is driving me mad ..... What level should the fuel be at relative to the float bowl gasket, when I set to the recommended 21mm the fuel level appears to be above the gasket level and presumeably below the overflow level as it is not overflowing but my thinking is that this is too high? Would appreciate other opinions.
Thanks Greg
Post by looey on Oct 7, 2017 16:19:43 GMT 1
Post by stusco on Oct 7, 2017 16:57:16 GMT 1
I always thought it should be the same height as the gasket, I bought dodgy carb kits once and the gaskets didn’t fit properly and they leaked so I fitted my 20 odd year old ones back in nd they sealed! Get proper gaskets
Post by victor on Oct 7, 2017 19:03:07 GMT 1
Thanks for thoughts. Bought a second new set of gaskets and they were much worse than the first hence my frustration! As they are fibre I can not see them working when constantly wetted with fuel? Will try setting just below the gasket. Any gasket sealants that work with petrol? Greg
Post by stusco on Oct 7, 2017 19:12:20 GMT 1
Shouldn’t need sealant you will need in there often ,have you tried norbo or allens for genuine gaskets
Post by midlifecrisisrd on Oct 8, 2017 10:43:56 GMT 1
No sealant on a float bowl gasket
If the gasket ain't sealing due to it being crap or damage on the faces.
We're they genuine gaskets
Doesn't matter where you set the float levels. When your leaning round corners the fuel will be on the gasket join anyway
When you do fit new gaskets I'd nip the screws up then leave overnight as the gaskets crush a bit.
Next morning you can always get a half turn on the screws
Post by Tobyjugs on Oct 8, 2017 11:07:56 GMT 1
Did you replace the O-rings around the new needle valves?
Post by looey on Oct 8, 2017 11:13:11 GMT 1
Did you replace the O-rings around the new needle valves? I don't think he has any probs with float heights or carbs overflowing, just float bowl gaskets weeping ?.
Post by Tobyjugs on Oct 8, 2017 11:19:37 GMT 1
Have you got any pictures for us of the carb and bowl faces to see and one of the gasket used. I have used Rob on here for float bowl gaskets and never had a leak with these. His name on here is 4l04ever, pm him.
Post by TZ750D on Oct 8, 2017 14:48:58 GMT 1
If the new gaskets don't seal they will leak when the bike is started up due to fuel sloshing around. I used some new gaskets out of a k and l kit on my Z1 (I wouldn't use any jets, needles etc out of those kits) and even nipping them up 3-4 times they still leaked. Only use genuine gaskets, and soak them overnight in fuel first. As others have said, don't use any sealant
Post by steven on Oct 8, 2017 14:54:40 GMT 1
...have the jointing faces or the carb been damaged by over zelous "tapping" with a screwdriver or something heavier when the float valves stick ? As per the Haynes manual, the 21 mm measurement is taken from the carb body gasket face. As you will see, there is a "notch" on the side of the carb body, where the float bowl mates with the carb. I have never seen it written down anywhere, but the only reason I can think that this notch is here, is to use while setting/checking the float height using the clear pipe method, as the top of this notch, is in line with the gasket landing/mating face. steven. rdlccrazy.proboards.com/thread/20423/float-heights
Post by victor on Oct 8, 2017 22:02:37 GMT 1
I am having problems getting the float height right but my original problem was weeping gaskets. I am pretty sure the fuel level is too high when set at 21mm though it is not coming out the overflow. I was unsure where the fuel level should be but the view seems to be just below the gasket but the view also seemed to be that it should not leak regardless of the fuel height? The float valves and O rings are new and do stop the fuel flow when operated manually with the bowls off. I think the discrepancy in heights might be because there is some wear where the float tang contacts the float. Ideally I suppose floats should be replaced as well but seem expensive if I can just compensate with the height and they are not he cause of the problem. I had not heard of soaking the gaskets overnight to get them to seal. I have sent pm to Rob. Greg
Post by richclare on Oct 9, 2017 6:52:54 GMT 1
Hi Greg,
I have exactly the same problem after my rebuild. The carb gaskets are new and seem to leak like a sieve! The old gaskets (I think were original) did a much better job of holding the fuel in. I am going to buy some replacements.
Rich
Post by richclare on Oct 15, 2017 14:21:44 GMT 1
Just a question to add to this link.....
I have a similar problem with the float bowl gaskets. I've changed them once and they leak, actually it's more like seeping, leaving a film of fuel on the float bowl side. I think it's because they were cheap so I have ordered some new ones from Norbo. I wanted to know if anything has to be done before fitting them. I know someone said to soak them in fuel overnight before fitting? Any other tips would be appreciated.
Cheers
Rich
Post by earthman on Oct 15, 2017 14:38:10 GMT 1
It's been many years since I've stripped carbs, never heard of soaking a new gasket in petrol before, what's the theory behind that then?
Post by richclare on Oct 15, 2017 15:59:24 GMT 1
It's been many years since I've stripped carbs, never heard of soaking a new gasket in petrol before, what's the theory behind that then? It was mentioned earlier in this thread.... I assume it helps to swell the gasket first? Rich
Post by 4l04ever on Oct 15, 2017 20:21:55 GMT 1
You can rub a thin smear of grease onto the gaskets to make them less porous. Let us all know how you get on.
Post by richclare on Oct 15, 2017 21:35:36 GMT 1
You can rub a thin smear of grease onto the gaskets to make them less porous. Let us all know how you get on. Thanks for the tip. I will post the result - fingers crossed. Rich
Post by philymon on Oct 17, 2017 9:57:35 GMT 1
Set mine at 20 mm from base of float bowl to just as float was touching shut of valve, checked after reassembly using clear tube and found 5 mm difference between left and right, could be tension diff. In shut off valve but even higher than base of float bowl it didn't leak,
Post by richclare on Oct 20, 2017 13:49:42 GMT 1
Received my carb repair kit from Norbo. The new gaskets are fitted and no leaks☺. I presume the old gaskets, which I bought from ebay, were poor quality. I did put a thin smear of grease on the gasket too, before fitting.
Rich
