Post by wangwang on Sept 26, 2017 22:11:18 GMT 1
I'm trying to make an RGV 250 front wheel fit in Triumph street triple forks, the easiest way I guess is to change the bearings. Has anyone any recommendations on who may be able to help? Triumph spindle is 21mm RGV is 18mm. Cheers Wang
Post by oldelsieboy on Sept 26, 2017 22:14:30 GMT 1
I'm trying to make an RGV 250 front wheel fit in Triumph street triple forks, the easiest way I guess is to change the bearings. Has anyone any recommendations on who may be able to help? Triumph spindle is 21mm RGV is 18mm. Cheers Wang If the correct sizes are available SIMPLY BEARINGS should have them OEB
Post by midlifecrisisrd on Sept 27, 2017 12:11:22 GMT 1
You may have to make reduced for the forks as the rgv bearings don't have a large outer diameter
