Post by barney on Dec 6, 2017 21:39:46 GMT 1
What swingarm and forks are you using ? Keeping it standard with a few little extras 😁
Post by barney on Jan 24, 2018 20:26:26 GMT 1
Well been quiet on the rebuild due to Xmas and other things so glad to see something coming together 😁 Rebuilt the forks at my mates and picked up my coated frame and polished yolk, new taper bearings fitted and new yss shock arrived today, I don’t normally keep my bike in the lounge but it’s been raining all week and the shed is at the bottom of the garden so can’t take it out in the wet😂😂
Post by dusty350 on Jan 24, 2018 20:39:20 GMT 1
Looking good Barney. I think it should stay in front of that radiator until Spring It's no good keeping it in a dark and damp shed !!Plus you'll build it much quicker if you are in the warm and dry Dusty
Post by jakethepeg007 on Jan 24, 2018 20:46:11 GMT 1
Good luck on your build, hopefully I'll not be to long and I start on mine!
cheers
Post by barney on Jan 24, 2018 20:56:56 GMT 1
Looking good Barney. I think it should stay in front of that radiator until Spring It's no good keeping it in a dark and damp shed !!Plus you'll build it much quicker if you are in the warm and dry Dusty Thankyou dusty i have tried explaining this to my wife at great length but it’s not sinking in😂😂
Post by barney on Jan 24, 2018 20:58:09 GMT 1
Good luck on your build, hopefully I'll not be to long and I start on mine! cheers Thankyou mate
Post by dusty350 on Jan 24, 2018 21:05:06 GMT 1
Just tell her how much it will be worth when it's done ! You wouldn't leave a painting worth thousands down the shed, so why would you do it to a bike as rare and desirable as an Lc ? And she gets time to spend with you whilst you rebuild it in the house - what more could she want Dusty
Post by lloydrj on Jan 24, 2018 21:46:56 GMT 1
Watching the thread with interest!
just ordered more parts for my resto :-)
Keep up the good work!
Post by barney on Jan 26, 2018 21:33:26 GMT 1
Just tell her how much it will be worth when it's done ! You wouldn't leave a painting worth thousands down the shed, so why would you do it to a bike as rare and desirable as an Lc ? And she gets time to spend with you whilst you rebuild it in the house - what more could she want Dusty I tried in vain mate but it’s now down the shed! I can’t tell her how much it’s worth as she’ll know how much I’ve spent 😂😂😂
Post by dusty350 on Jan 26, 2018 21:42:29 GMT 1
Ah well, never mind ! We are nearly out of January now, so February to go and then the weather in March starts to cheer up. Evenings are already starting to draw out, so shed time should start to get a bit more enjoyable Keep the updates coming. Dusty
Post by barney on Jan 27, 2018 21:29:29 GMT 1
Brought my swinger up from the shed and gave it a quick polish before I start the chassis
Post by Deleted on Jan 28, 2018 10:10:30 GMT 1
All looking very good Barney. Excellent job on the crank cases and with other posts, love all the shiny bits!. Keep up the good work and I look forward with interest to the progress. Man after my own heart: can get it wet!!
Post by barney on Jan 28, 2018 18:45:32 GMT 1
Thankyou penno Been a long time getting things sorted so it’s nice to see a few things coming together now 😁
Post by philmill on Jan 28, 2018 19:30:28 GMT 1
she's going to look sweet with that swinging arm! very nice.
Post by barney on Feb 21, 2018 21:46:11 GMT 1
Well done a little more and my mate has got the motor together just waiting for the side cases to come back from blasting and polishing a little peeved as whilst handling the motor a piece of the crankcases decided to shear off ffs from the front mount hopefully it won’t have any effect on it😬
Post by jessy03 on Feb 21, 2018 22:02:01 GMT 1
Looks very nice’n shiny, don’t forget the reeds Jess
Post by barney on Feb 21, 2018 22:28:31 GMT 1
Looks very nice’n shiny, don’t forget the reeds Jess Ha ha thanks jess the reed blocks are being cleaned at the mo 👍
Post by ringding on Feb 21, 2018 23:10:46 GMT 1
Looking good!
Post by barney on Apr 4, 2018 22:13:54 GMT 1
Been a bit quiet on the rebuild due to a few other things going on but got the motor finished now so will get her in the frame this next week and hopefully move things on a bit Spec on motor is ... Recon crank 2.5 os mitika pistons and rebore Reprofiled head to accommodate piston crown All bearings replaced through out motor New selector gear shaft Power dynamo Clear clutch window Refurbed oil pump from arrow
Post by dusty350 on Apr 4, 2018 22:19:09 GMT 1
Engine looks awesome Barney - great job Dusty
Post by donkeychomp on Apr 4, 2018 22:19:57 GMT 1
That is coming along very nicely, great work Barney.
Post by barney on Apr 6, 2018 7:27:02 GMT 1
Engine looks awesome Barney - great job Dusty Thanks dusty will get some pics up when the motors in👍
Post by barney on Apr 6, 2018 7:37:45 GMT 1
That is coming along very nicely, great work Barney. Alex Thanks Alex
Post by barney on Apr 15, 2018 20:32:27 GMT 1
Post by barney on Apr 15, 2018 20:38:31 GMT 1
Few more bits done Swinging arm now fitted had to get some shims made as when I originally offered it up the gap between dust cap and frame was around 2mm each side so a little slack! New rear muddy New yss shock Polished engine mounts Carbon headlight New switchgear Also do I have the bar clamps the right way up as there are 2 dots on them and I presume it shows orientation ? Next to tackle is the clocks then the wiring loom And I also have something special turning up hopefully Thursday 😁😁
Post by barney on Apr 15, 2018 20:48:48 GMT 1
Post by scooter on Apr 25, 2018 19:30:00 GMT 1
looking good barney some nice bits on there and plenty of trick bits from norbo I see
Post by barney on Sept 6, 2018 20:57:14 GMT 1
Well haven’t touched the bike for a little while as it’s had to take a back seat due to a few things going on😬 Hoping to start getting it together a bit more the next couple of months so here’s the latest bits I’ve sorted really pleased with the wheels as a lot of work has gone into them and the nk disc conversion looks awesome can’t wait to get it in the frame
Post by barney on Sept 13, 2018 22:36:52 GMT 1
Put the wheels in tonight NKs rear disc conversion looks great in the metmachex swinger, front wheel needs to come back out though as when I torqued the spindle the wheel tightened up so will have to check spacers etc, After a lot of consideration I’ve ordered the new metmachex swinger with slotted adjusters just can’t help myself with this shiny stuff😬so I’ll be putting this one up for sale shortly Carbs are boxed up ready to go off to muttsnuts for a service and set up, Next up will be a tail tidy and then look at the wiring which I’m not looking forward to
Post by dusty350 on Sept 14, 2018 7:55:59 GMT 1
Wow, looking really trick Barney That rear disc conversion looks fantastic. It's gonna be a lovely looking bike for sure. And I think the Met arm with the slotted adjusters is a good idea - sell your existing one and it wont seem an expensive swap Dusty
